P0111 Intake Air / Charge Temperature Sensor Performance / Rationality
Old Jun 15, 2005 | 07:19 PM
MedicShawn's Avatar
I put an Sp Diesel box on my truck. I got a couple of codes.
P0237 Turbocharger Boost Pressure Sensor Low
p0069 BOOST KEY ON RATIONALITY
I cleared the last 2 but the first one came right back.
Even with the box disconeccted I still have the intake temp sensor code being thrown. Any ideas on troubleshooting besides just replacing the sensor?
Old Jun 15, 2005 | 07:49 PM
spdiesel's Avatar
I think we have sent you an email responding to your question, but here goes for others who may be interested.
The 111 code is a result of a manifold air temp versus intake air temp correlation that happens on cold startup, we have had this issue pop up on a few trucks and are working on a permanent solution. We are willing to modify your harness to solve this issue, but the box may be derated a little.
Don't worry about the code still being there your sensor is fine. With the truck returned to stock it takes a couple cold start cycles before the code will allow itself to be cleared,even with a scan tool. This behavior makes it a real bugger to diagnose the issue sometimes.
Old Jun 15, 2005 | 08:22 PM
MedicShawn's Avatar
Thanks for the quick reply. Hopefully the new harness will cure my problem. I'm just getting tired of that annoying Light.
Old Jun 17, 2005 | 09:17 AM
trik396's Avatar
Let us know the results. Thanks
Tony
Old Nov 14, 2010 | 08:10 PM
steelbluenj's Avatar
i have the same code coming up. PO111
what am i looking at here. i see this is an old thread but i didnt see the out-come or any answer to this problem...?
thrashingcows
Jun 21, 2014 01:16 AM
Thunderhog
Jun 3, 2009 07:47 PM
.boB
Mar 12, 2009 09:42 PM
Foxborough
Apr 19, 2006 06:57 PM
MoparKen
17
Mar 28, 2006 07:47 AM
