second fuel tank, what might be wrong with this?
Old May 3, 2003 | 10:08 PM
gadgets's Avatar
Re:second fuel tank, what might be wrong with this?
<br>Could be wrong, but it seems to me that you better put a shut-off valve in that hose down to the fill neck or you'll just overfill a full main tank &amp; leak it all out on the ground... ???<br><br><br>Rene<br>
Old May 3, 2003 | 11:43 PM
Jim O's Avatar
I would recommend a shutoff valve so you can change or clean the filter but you will not leak on the ground unless you leave the cap off the factory tank. there is a one way check valve in the cap. I tried a &quot; wally world filter and it would not flow enough in cold weather. so I went to one with a sediment chamber and a screen that can be cleaned. <br>Jim O
Old May 5, 2003 | 05:34 PM
johnh's Avatar
i have a homemade aluminum 50 gal tank . i put a cheap electric pump after an in line fuel filter.it`s plumbed in the filler neck ... when i transfer fuel (about 25 gallons) it takes about 20 minutes while i`m going 75 or 80 across nebraska : : :
Old May 5, 2003 | 05:57 PM
Shovelhead's Avatar
Administrator / Scooter Bum
One reason those aux. tanks are kinda expensive, is they have to be able to survive an accident/rollover without spraying everything down with fuel.
We never plan for an accident, but it might be something to keep in mind &quot;Just in case&quot;.
No one wants to pay huge $$$ for a Hazmat Cleanup when a homemade tank ruptures and diesel fuel goes everywhere in an accident.
Ed
rollincoal07
Mar 1, 2008 12:29 PM
rstone
Aug 16, 2007 12:56 PM
firstdieselram7
Mar 12, 2007 06:58 PM
Ridgerunnerras
Jan 10, 2007 01:56 PM
