searched but found no match
Old 06-22-2007, 03:01 PM
apprentice's Avatar
when i first drove my truck at wot it made a groan. as well a vibe that was felt in the go pedal and the stearing wheel. it seems to be happening sooner like half throtle or when climbing a grade and gets worse the closer i get to wot ... this is a new thing. never made any other noise on a grade before just a more intense diesel sound and turbo spool. did a search for noises groans viberations nothing seems to match... any ideas??? no miss idle seems fine.
Old 06-22-2007, 03:56 PM
DanMan's Avatar
Can't help ya on yer problem there, but......
How's that spring workin' for ya in the glove box there?
Sorry... just couldn't resist!
Old 06-22-2007, 05:47 PM
Pop the intake hose off the turbo and check the shaft for play. Also look for exhaust leaks.
Old 06-23-2007, 01:19 PM
Boatnik's Avatar
AND while looking for an exhaust leak, check to see if the exhaust pipe is hitting the frame anywhere. Mine had a killer drone because of the pipe rubbing the frame next to the tranny.
Old 06-23-2007, 04:47 PM
apprentice's Avatar
seems to be with school and work i just cant take the chance that my truck could be out of commision for more than one day if i screw somthing up... but at least i know where it is and have dloaded the howto ... just a time factor
Old 06-23-2007, 04:50 PM
apprentice's Avatar
shaft is good spins free. tight as far as end play... how do i check for leaks someone said plug tail pipe ?
Old 06-23-2007, 04:52 PM
apprentice's Avatar
drone is a great word for what is happening. gonna check leaks and contact spots today
Old 06-23-2007, 11:13 PM
You can see them if you have somebody start the truck while you watch. The puff of smoke makes leaks jump right out at you.
Old 06-24-2007, 02:46 PM
pred's Avatar
Might want to check u-joints for wear,,,, Grease them up real good and see if the issue is still there.
Old 07-08-2007, 01:02 PM
apprentice's Avatar
no exhaust is touching any part of frame or leaking, turbo seems fine. it is getting worse.... what next ??? seems to have plenty of power
berok
04-27-2006 10:01 PM
rentalguy
12-09-2005 08:33 PM
jiMMyCTD
07-12-2004 03:52 PM
Maccandy
05-16-2004 09:25 AM
JaimeZX
05-12-2004 11:36 PM
Quick Reply: searched but found no match
