searched but found no match
when i first drove my truck at wot it made a groan. as well a vibe that was felt in the go pedal and the stearing wheel. it seems to be happening sooner like half throtle or when climbing a grade and gets worse the closer i get to wot ... this is a new thing. never made any other noise on a grade before just a more intense diesel sound and turbo spool. did a search for noises groans viberations nothing seems to match... any ideas??? no miss idle seems fine.
Can't help ya on yer problem there, but......
How's that spring workin' for ya in the glove box there?[laugh] [laugh] Sorry... just couldn't resist! [duhhh] |
Pop the intake hose off the turbo and check the shaft for play. Also look for exhaust leaks.
AND while looking for an exhaust leak, check to see if the exhaust pipe is hitting the frame anywhere. Mine had a killer drone because of the pipe rubbing the frame next to the tranny.
Originally Posted by DanMan
(Post 1565665)
(Post 1565845)
Originally Posted by Boatnik
(Post 1566812)
Originally Posted by apprentice
(Post 1567036)
shaft is good spins free. tight as far as end play... how do i check for leaks someone said plug tail pipe ?
Might want to check u-joints for wear,,,, Grease them up real good and see if the issue is still there.
no exhaust is touching any part of frame or leaking, turbo seems fine. it is getting worse.... what next ??? seems to have plenty of power
