Rough Idle on Startup
Old Jan 8, 2007 | 07:59 PM
skipperw's Avatar
The last couple of weeks my truck has a rough idle on startup and sometimes puts out some blue smoke. It quits when I give it a little gas pedal and raise the RPM above 1000 and then its fine the rest I drive it. I thought it might be because it has been cold here in Utah, but today it was 40 and it still did it. I have it pluged in at night..no change. Any thoughts?
Old Jan 8, 2007 | 08:56 PM
adkl1's Avatar
mine does it to for like 3 seconds at start up and i live in phoenix. im not to concerned about it for right now but im keeping an eye on it. 06 ctd 4x4 15k miles
Old Jan 8, 2007 | 09:17 PM
BigHornCTD's Avatar
Mine has also been doing this for the last 4000 miles or so. It is intermittant but happens a few times a week. The very first time it did it, I got a CEL. The dealer relashed the computer, but I am still having the same issue without any more CEL's.
Last time I was in for service, I told them I was still having some trouble. He said they have been getting quite a few complaints. He said there is not much they can do at this point until it gets more consistent or throws another CEL.
Old Jan 8, 2007 | 09:45 PM
GOTMEAT's Avatar
I've had it too. It also goes away once I get rolling.
Old Jan 9, 2007 | 03:46 PM
skipperw's Avatar
Thanks for your input
Old Jan 14, 2007 | 06:50 AM
gnarlykaw's Avatar
Theirs a TSB for this but it's a pain to check out. either a VP or nozzles...........
Old Jan 14, 2007 | 11:24 AM
stang's Avatar
mine will do the same from time to time, 40 is still cold for a diesel. I use to worry about it also but I dont belive you have any problem any more then anyone on here has had its common. you can check the heater grid make sure it is working or can cycle the key a few times to get some more heat in the intake air charge before start up. Seems when I have my truck pluged in the heater does not stay on as long on the first start up so I got tired of the smoke and cycle the key a few more times before start and its clean on start up. And there is a TSB for white smoke on start up so I would check into that also. check your oil if the level is fine (not high on the dip stick) you should be fine
Old Jan 16, 2007 | 02:39 AM
BNH4221's Avatar
I get the same thing occasionally in the winter on a cold start up. I found that it goes away if I stomp on it once in a while and really work the motor (after it is warmed up of course).
I think there gets to be come crud on the injectors and they need to be blown out every so often. At least thats my story and I'm sticking to it!
Steve
t-boe
89
Jul 16, 2009 07:51 AM
JThiessen
Jul 29, 2008 04:27 PM
Dodgezilla
16
May 8, 2007 05:38 AM
JIMCTD
Nov 5, 2006 03:14 PM
big red psd cc
Sep 1, 2004 01:39 PM
