How restrictive is the stock exhaust?
Old 07-08-2010, 10:33 PM
MissionRam's Avatar
I have gone from a Edge EZ to a comp box and I can't keep my EGT'S below 1300 while towing. On level 5 with just the truck I peg the gauge. I have a cat back flow master 4" muffler and tail pipe. If I wen't to a turbo back 4" system would this help or is my turbo at it's max.
Old 07-08-2010, 11:36 PM
J Lent's Avatar
The exhaust isn't as restrictive as you would think. I know a guy running a stock exhaust on his 12v. He laid down 541hp & runs cool. The turbo is the restriction.
Old 07-09-2010, 01:15 AM
ellerman's Avatar
If you peg your pyro just driving your truck something is wrong. Level 5 can be a little much for towing depending on load but you should have no issues for normal driving. Are you able to build boost?
Old 07-09-2010, 10:37 AM
Lil Dog's Avatar
If its an auto with the HY35 turbo, not that uncommon. The 9cm exhaust housing is the restriction.
Old 07-09-2010, 03:12 PM
maroonbeast01's Avatar
my stock exhaust was so restrictive that i had to cut it off infront of the catalitic converter in walmart parking lot just to get the truck to start and when she came alive it was like all hell broke loose and she could breathe again.
Old 07-09-2010, 08:05 PM
MissionRam's Avatar
I tow on level 2 and drive on 3X3. It gets hot when the engine is at lower rpms (1500) but it makes good power down there. I think I need a turbo and new exhaust.
Old 07-13-2010, 07:18 AM
nkennedy's Avatar
How come you have a CAT on a 2001. I don't have a CAT on mine, and it was my understanding it didn't come with one.
Old 07-13-2010, 07:30 AM
mine had one i dont know why my grandparents ordered the truck custom from the factory it was a weird setup the way they did it all i know is that now i am running 4in turbo back to a single 8in straight up stack and the truck loves it changing the whole exhaust set up really woke my engine and turbo up my g/f whines when i pull a 26' gooseneck with our big tractor on it cause the truck roars and of course i roll the windows down
Old 07-13-2010, 09:46 AM
Beast2B's Avatar
i don't think any 01s came with a cat. there is a resonator ahead of the muffler, but no cat converter.
to the OP-- low rpm is not the optimum place for your truck for egt cooling. the turbo needs to be spooled to flow more air. keep the revs up. towing at 2000-2500 works best for my towing needs and it will GENERALLY get better mileage up there, too. just my experience, and yes, the motor can run 2500 all day long.
Old 07-13-2010, 02:29 PM
PaulDaisy's Avatar
I agree, above 2000 RPM is the area where the EGTs cool down. However, I get worse fuel mileage than when running at 1850 RPM.
C Schomer
11-04-2006 05:17 PM
EKUgrad
15
10-13-2005 08:36 AM
mbenedict
08-24-2005 05:52 AM
nicksort
06-30-2003 05:51 PM
The Boss Hog
34
01-10-2003 04:51 PM
Quick Reply: How restrictive is the stock exhaust?
