Restrictive Aircleaner
Old Oct 28, 2002 | 06:54 AM
The Boss Hog's Avatar
Guys,<br> Early on I remember a few guys mentioning that the air-filter indicator had pulled down after they had taken an HO for a test drive. Have any of you new owners noticed this on your trucks? If so, what has the dealer had to say about it? Thanks,<br><br>The Boss Hog<br>Waitin' and Worryin'<br>
Old Oct 28, 2002 | 08:56 AM
pwabbott's Avatar
Re:Restrictive Aircleaner
Boss Hog, I have 1800 miles on my 2003, mostly towing. I've checked my air filter indicator a couple of times and it's pulled down to one-third. Each time I reset it. I havn't driven in any dusty conditions. This indicator could be the best sales-person on the block.
Old Oct 28, 2002 | 09:00 AM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
I'll go with what Phil said. My indicator seems to spend most of its time at 1/3 down. I haven't bothered talking to a dealer, as its most definitely a restrictive airbox. The stock HO is capable of pulling 27lbs of boost, and the airbox just can't keep up with it.<br><br>Rod
Old Oct 28, 2002 | 08:52 PM
tobyw's Avatar
Ditto on the 1/3 here. Thought about poking some holes in the box, but I figure rather than risk any warranty type issues, I will let DC figure something out. Certainly doesn't affect how she pulls!!! ;D
Old Oct 28, 2002 | 09:05 PM
Push Rod's Avatar
What I can't quite figure out is how they keep the EGTs so low with such a restrictive airbox. At 105 MPH, my EGTs never get above 1050F. Cummins must be making a pile of power with timing advance versus fuel.<br><br>Rod
Old Oct 28, 2002 | 09:21 PM
FiverBob's Avatar
Help me guys - - what is the air cleaner indicator??? Where is it and what does it do?<br><br>I know, it is probably in that encyclopedia that came with it that I am only 1/2 way thru reading. :P<br><br>PuzzledBob
Old Oct 28, 2002 | 09:28 PM
Commatoze's Avatar
Pop your hood, Bob, and take a look at your air filter box. There's a little clear cylinder standing up on it. Thats the filter minder. The way it's supposed to work is as your filter gets loaded up, the little resettable indicator will get pulled down to the &quot;replace&quot; indication. You replace the filter and reset the spring indicator by pushing the button on the top.
-Tom-
Old Oct 28, 2002 | 09:46 PM
FiverBob's Avatar
Thanks, Commatoze,<br><br>There is a little plastic thingy sticking out the side of my air box - - have not had the thing long enough to figure out what everything is under there. I will check it tomorrow. Makes sense, unless the box is too small.<br><br>Bob
Old Oct 29, 2002 | 12:02 AM
Scotty's Avatar
Top's Younger Twin
I do believe theres a Scotty Air III in the works for the 3rd gen trucks. ;D<br><br>Just a hunch of mine...thats all.
Old Oct 29, 2002 | 07:35 PM
pwabbott's Avatar
That plastic thingy is not an original, check your wife's vaccum cleaner it has a filter (Bag Indicator). My wife's vaccum starts out with new bag at 1/3 full. It continues to suck good until it gets about 3/4 full, stops sucking at full. That's when I hear, &quot;something's wrong with the vaccum&quot;. I doubt that our plastic thingys are precision instruments, just something else to remind us that filters need to be cleaned once iin awhile.
Old Oct 29, 2002 | 07:49 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Non Precision thingy's? who would have ever thought? <br> Phil you got a way with words there buddy!
Old Oct 29, 2002 | 08:58 PM
Dieseldude4x4's Avatar
Is it a thingy or is it really a thingy-mabob on the whatcha-majigger connected to the dumaflotchee? Ya's gotta get these terminology things right you know.
Old Oct 29, 2002 | 10:49 PM
Hunter's Avatar
Phil<br><br>Correct me if I am wrong, say wording &quot;it continues to suck&quot;<br><br>The CFO is not gonna like your choice of words!<br><br>Hunter
Old Oct 31, 2002 | 10:54 AM
wantabee's Avatar
Mine also shows down 1/3rd...has anyone called DC on this yet?<br><br>Wantabee
Old Oct 31, 2002 | 09:05 PM
pwabbott's Avatar
I opened my air box today and examined the filter. Surprise, it is beginning to look dirty. Not bad put the tops of the fins are charcoal already. Must be filtering out the polution of the vehicles in front of me. Some 1900 miles of use. Reads 1/3 at present. When it gets to 50% I'll clean it by blowing from back side and see how the reading changes after cleaning.<br><br>It also looks like the fins are closer together, hard to tell. I is about 50% larger than the one on my 98 Ram 5.9L gasser. 8)
