Remote trans cooler install...w/pics
Well, I didn't have room up front for a tranny cooler so I had to get a remote one... I went with one from B&M with a little fan on it and auto thermostat... Here are a few pics of what I did... I still have to hook up power and run my lines... But that is the easy part and tomorrow is another day!! Thanks to BC for answering my questions...
Thanks guys, here is a link to the fan... I chose this one because of the mounting area around the fan... Others I was looking at didn't have anyplace to secure a framework around...
http://www.bmracing.com/s.nl/c.72308...&category=6173
Ya..thats funny... I have the truck in my Step Dads barn and those are my moms plants... Wasting space in a nice barn for plants...My Step Dad told me I had untill thanksgiving to get my truck out of his Barn... So... I am scramblin... I'm almost there..
To help ensure you get all the fan's good for, power it by way of a relay fed with 10awg wire.
- Wire it like the headlight relay trick. Have the control (thermostat/manual over-ride) power the relay, and the 10awg (fused) from the battery power the fan by way of the relay's contact.
- An option would be to have a line run back to the cab from the actual fan's hot wire. This can be used for powering an illuminated (manual/auto) switch. The light would act as proof the fan's getting power be it automatically by the thermostat, or by way of the manual over-ride.
David... Why would I use 10 ga wire, to me that seems way overkill... The wire leads out of the fan are like 16... I am not the best with wiring... the fan is only supposed to draw like 10-12 amps... So... why the need for such heavy ga wire?? Thanks
Also, if you're gonna run the fan's ground to the frame (and why wouldn't you?), be sure to add a 10awg jumper from the battery's negative terminal to the sheet-metal of the body. The OEM body connection to the neg terminal is dinky at best. Everyone should do that one upgrade and will most likely see everything get a bit brighter.
Undertaker
Oct 26, 2009 03:02 PM
malojeer
Aug 20, 2007 10:37 PM
QWKRTNU
Sep 26, 2006 10:22 PM
live wire
Jul 21, 2003 07:26 AM
drafalske
Apr 5, 2003 01:45 PM
