Rear Window Leaking
Old 10-20-2006, 11:59 AM
rjm022's Avatar
Rear Window Leaking
Noticed today, with all the rain we have had, my rear window is leaking from the top section, right above the rear back seat head rest (on the drivers side). (I have the rear sliding window, but that doesn't seem to have any correlation to the area that is leaking.) I wiped the water and watched and I could see it coming through the seam. From the outside it looks like the water is seeping in from behind the top rubber portion of the window. The only fix I can see is dropping the headliner and siliconing the seam from the inside. How hard is it to drop the headliner? Any ideas or comments?
Thanks,
Old 10-20-2006, 05:47 PM
linetrash75's Avatar
Before dropping your headliner check the seal around your third brake light. That could easily look like rear window leaking. My 98 did.
Jed
Old 10-20-2006, 06:05 PM
rjm022's Avatar
thanks jed- i'll do that first!-right now!
Old 10-20-2006, 06:22 PM
rjm022's Avatar
ok- took the screws out and the third brake light lens won't move. feels like it is glued in there! i don't want to pull too hard- i don't want to snap it in half! what is the secret??
Old 10-20-2006, 10:07 PM
mine was kind of stubborn when I fixed it looked like a little foam gasket. I went back with black rv silicone.
Jed
Old 10-23-2006, 01:38 AM
carl20320's Avatar
Thanks,
I had the same problem with my 06. I actually looked like the water was coming in from uner the headliner so I did not think there was anyway it was the window. I assumed it was the third brake light or factory satellite antenna. Turned out it was the rear window seal. I had the dealer repair it under warranty. I think all they did was put black silicone on the seal but it does not leak any more. When I first went back, they thought third brake light too but it was not. They ended up replacing the seat cover as well since it spotted with the water.
Carl
Old 11-06-2006, 11:57 AM
jkravito's Avatar
I have the same leaking issue. Just noticed it this weekend after a big rain. This sounds like a warranty issue for sure if others are having the same problem.
06RAMCTD
11-21-2012 11:24 AM
Piston_bully
02-01-2012 04:45 PM
raven392003
10-29-2007 11:39 AM
roadie00
12-22-2005 07:10 AM
Sidewinder
11-03-2004 08:09 AM
Quick Reply: Rear Window Leaking
