Rear rotor removal on an 02???
Old Feb 25, 2006 | 10:20 AM
hotdram's Avatar
Exclamation Rear rotor removal on an 02???
Can anyone tell me how to remove the rear rotors on my 02? I have the caliper and caliper bracket off, but the rotor is not budging. The fronts were much easier.
If you can, please help, truck is in pieces as I type and I have a ride waiting to take me to get the rotors turned
Thanks,
~Rob
Old Feb 25, 2006 | 10:29 AM
hotdram's Avatar
Well, I did a search and bishgeo had the same problem I do, here is his response from a few years ago:
Originally Posted by bishgeo
Got it.Sat back and drank a few more beers and got out the BFH and pounded on it like a power stroke trying to pull a load of feathers.
"Yet another victory for Busch "
Apparently I am not drinking enough beer.
Will go try his method right now.
~Rob
Old Feb 25, 2006 | 02:01 PM
DIESELRYAN3500's Avatar
if i remember correctly, your axle and rotor are one piece ?? you have to open the rear end and remove the clips. '01+ trucks have both drum and disc brakes in the rear
Old Feb 25, 2006 | 02:39 PM
hotdram's Avatar
The rotors came off after I had a buddy rotate the tire on the opposite side while I beat on the back of the rotor with a rubber mallet. Took 'em to get surfaced but the shop said they were below the minimum thickness. Went to Napa and bought 2 new ones and put 'em on. While I was under there, I think I found the clunking I was hearing too, the spare tire was loose.
~Rob
Old Feb 25, 2006 | 02:44 PM
eric13's Avatar
If you dont mind me asking what did you have to give for the new rotors?
Old Feb 25, 2006 | 03:01 PM
hotdram's Avatar
I paid about $160, here in Texas, for the set. Carquest had some in stock that were about $7 cheaper a piece, but I went with the Napa ones.
My first choice would have been to order them from Tirerack.com and get Brembos. But, as it was, my truck was already apart (I thought I just needed to get them resurfaced) and I wanted to put some on today while it was torn apart. A few months ago, I put the Brembos on the front from Tirerack.com. They were $66.00 apiece. Shipped to my front door for about $140 bucks total. That is the way to go.
~Rob
Old Feb 25, 2006 | 03:05 PM
eric13's Avatar
Thanks Rob I will try the brembos I will be replacing mine soon.
Old Feb 25, 2006 | 05:42 PM
SEE WHAT HAPPENS WHEN YOU DRINK TOO MUCH N.L. THE NIGHT BEFORE !!
MY FATHER IS REALLY STARTING TO LIKE US !! ( V.P. MIKE HOPKINS DISTRIBUTING CO. ).
na4now
Sep 26, 2009 12:01 PM
ChrisG
Mar 25, 2009 02:40 PM
robbynne
Feb 4, 2009 08:39 PM
Steverfd
Jun 24, 2007 10:21 PM
Mototrout
Jun 10, 2006 11:19 PM
