Rear Brakes Dragging
Old Oct 15, 2009 | 01:48 PM
Keyser's Avatar
I had the seals redone last year, and since I was in there i replaced the rear pads. It seems that the rear brakes over tighten now. I can untighten them by rolling the star back, but they will over tighten again. It was suggested to me that it was the e-brake, so I stopped using it. They still drag. My pedal is also totally different now. The brake pedal has very little travel and my e-brake pedal also has very little travel. I looked on the forum, but it seems that most people have the opposite problem and their adjusters don't actually tighten. Any ideas?
Old Oct 15, 2009 | 05:55 PM
Clunk's Avatar
The self adjustment occurs when you come to a stop after backing up.
One option is to take the self adjustment lever off and do your own adjusting.
Old Oct 16, 2009 | 07:58 AM
nickg's Avatar
didyou do both sides at the same time and mix up the adjusters? or are the seals leaking again and there is a light film of oil on the shoes? if P-brake is stuck 1/2 way it will cause locking issues, you have to remove drum and physically force P-brake arms towards rear of truck to ensure they are fully released.
re-read post, when you back star wheel off do you need to push the adjuster arm away from the star wheel before it will back off? or do you just stick the tool in the hole and back off the brakes?
Old Oct 16, 2009 | 10:51 AM
Keyser's Avatar
Both sides were done at the same time. I have to pull up on the lever to get the wheel to move. If the p-brake is sticking halfway where does it stick? How do I fix that? I stopped using it, but my wife drove the truck and I know she used it. Do the cables get gunked up, or is it somewhere else?
Old Oct 21, 2009 | 11:32 AM
Keyser's Avatar
The adjusters like to adjust thats for sure. It looks like the rear ebrake cables are sticking. I guess i'll try replacing them and see what happens.
Old Oct 22, 2009 | 12:43 AM
wyododge's Avatar
I would try cleaning them first, then spray a bit of wd 40. I live on a dirt road and mine get a little tacky from time to time, especially after rain or snow. May not work for ya but it is easier and cheaper than replacing them.
Just my .02!!!
volly818
Feb 10, 2009 06:07 AM
sdsaw
Nov 26, 2007 11:45 PM
sdsaw
Nov 5, 2007 11:51 AM
skwelder
Nov 22, 2006 01:11 PM
OHFarmboy
Nov 21, 2006 09:50 PM
