Dragging Brakes
Old Nov 20, 2006 | 07:38 PM
skwelder's Avatar
Dragging Brakes
On my '03 Dualy the brakes are dragging. You have to give it a lot of fuel to get it to move, and as soon as you let off you can feel the truck slow down like you were pressing the brakes slightly. So I drove for about 3 miles and the front brakes heated up so bad they were smoking. The pedal feels diffent now it seems a lot tighter. Anyone ever had this or have an idea what would cause this. Thanks!
Old Nov 20, 2006 | 07:40 PM
mopargw's Avatar
Drums or disc in the rear?
Old Nov 20, 2006 | 07:43 PM
skwelder's Avatar
All Disc, they all seem to be draging, I had new rotors and pads put in the rear about 6000 miles ago.
Old Nov 20, 2006 | 07:48 PM
mopargw's Avatar
Did you jack up the front and rear and check each wheel to see if they are all dragging?
Old Nov 20, 2006 | 07:50 PM
mopargw's Avatar
Is your power steering still the same?
Old Nov 20, 2006 | 07:52 PM
mopargw's Avatar
Did you check the parking brake cable to see if it felt tight? It should be run in the driver's side of the frame, pull on it to see if it is still tight with it disengaged.
Old Nov 20, 2006 | 07:53 PM
skwelder's Avatar
No. I didn't check it.
Sidewinder's Avatar
Some more ideas on this thread.
https://www.dieseltruckresource.com/...d.php?t=124371
Old Nov 20, 2006 | 08:10 PM
mopargw's Avatar
skwelder,
I would first chcke the parking break and then determine if it is one wheel or all of them. If it is all of the wheels then I would lean tward the master cylinder.
Old Nov 20, 2006 | 08:24 PM
skwelder's Avatar
front brakes were smoking, parkbrake is working good.
Old Nov 20, 2006 | 08:57 PM
mopargw's Avatar
Could be a bad caliper. Can you figure out which wheel it is?
Old Nov 20, 2006 | 09:06 PM
skwelder's Avatar
Front driver side I I'm leaning toward a stuck caliper. I'll check it out tomorrow.
Old Nov 20, 2006 | 09:13 PM
skwelder's Avatar
I'm going to check the rubber lines also. My brake fluid looks fairly dark, do you think contamination would be the problem.
Old Nov 20, 2006 | 09:15 PM
mopargw's Avatar
The orifaces in the lines aren't that small, I would lean tward a bad or overextended caliper. Did you change the pads or did someone else?
Old Nov 20, 2006 | 09:31 PM
skwelder's Avatar
local dodge dealer did them for me.
