Raptor or AirDog?
Old Feb 1, 2012 | 11:24 AM
Nate-03 D's Avatar
Raptor or AirDog?
Hey guys. If this has been beaten to death before, sorry . Don't flog me to bad.
I currently have 126k miles on my stock LP in the truck in my sig. I 'm looking to pull the trigger on a new pump setup before mine bites the dust.
I 'm in a debacle over which system to go with. I 'm sure the AD is far superior to the Raptor but I'm having a hard time justifying the almost $600 price tag for that setup.
Here's what I need help sorting through.
On the AD system, I keep reading about a draw straw/ 1/4 tank fuel issue? Would I have to remove my bed/drop the tank in order to install? Could my original LP be left in and operable in case the AD fails?
On the Raptor system, I understand it's just the pump by it's self. Does it just hook up to the OEM LP and pull extra fuel and run it through my firewall mounted filter? Would it be worthwhile to install a second fuel filter and "pretend" I have the AirDog setup?
I did a little looking/reading and have been seeing that these aftermarket systems run about 18psi, and the CP3 likes it to be between 8-12psi. Any reported issues with this or am I just misinformed?
Old Feb 1, 2012 | 12:27 PM
gpshemi's Avatar
I haven't been able to figure this out either. My Outlook monitor shows good injection pressure even when romping on crazy larry. I see the CAT 2micron filter setup and wonder if I really need an airdog before mine fails or just the CAT system for $170. Been thinking about a new turbo, perhaps it won't keep up after that. IDK.
SUBSCRIBED.
Old Feb 1, 2012 | 12:51 PM
Nate-03 D's Avatar
Does your Outlook show Rail Pressure or Fuel Pressure? My FP holds real steady at 10psi. My RP is right where it should be aswell.
I forgot to mention in the original post. Eventually i'll put on a larger turbo, a small set of injectors and a CP3 "bag of pats" and would like to make a solid 450-475 horse. Is the Raptor capable of handling this or is that a job best left suited to the AD?
Old Feb 1, 2012 | 01:16 PM
gpshemi's Avatar
You sound like you're on the same path as I am. II's CP3 bag o parts, larger turbo for towing (62/65/14?), and some 50-90hp nozzles.
Outlook reads injection control pressure - rail pressure. I never watched it intently, but seems limited to low 20k when I look.
Edit: Just went and picked up the kids. 23k at WOT on crazy larry.
Old Feb 1, 2012 | 02:27 PM
1SlowVE's Avatar
Air Dog has them preset to 15-17 at idle. You will more than likely see a drop at WOT though. The benefit to the AirDog150 is the added filtration if you havent already put an aftermarket filter system on it. As far as the 1/4 tank issue, we have NEVER had that issue with draw straws. This includes putting Dodge systems on Ford Conversions. 95% of 1/4 issues are installer error, they don't contribute sag into installing the draw straw. We always drop the tank to install the draw straw as its easier in my opinion than pulling the bed and saves time. And yes you can leave your factory pump in for the rare occurence of the AD failing.
Old Feb 1, 2012 | 11:59 PM
Nate-03 D's Avatar
Thanks for the info. Im still a little foggy on the term "draw straw", is this just a tube that sits deep in the tank and supplies the fuel to the AD/Raptor pump?
If I were to leave my factory mounted pump/filter housing in what does the AD system connect to, directly to the CP3? Would I have to run a switch of some sort or physically re- connect lines to get the OEM setup running if the AD system goes south?
Old Feb 2, 2012 | 01:34 AM
Dr.Dizzle's Avatar
You have an 03 with the factory pump mounted to the filter housing correct? Or, has the truck been retrofitted with the in tank fuel pump?
Old Feb 2, 2012 | 06:49 PM
Nate-03 D's Avatar
Correct, it still has the original pump mounted to the housing. Well at least I believe it does, bought the truck w/ 20k miles on it and no records indicated any fuel pump work.
How would I go about verifying for sure it's still original?
Old Feb 2, 2012 | 08:00 PM
Dr.Dizzle's Avatar
The pump is located on the rear of the fuel filter housing and is black in color. Since you purchased the truck with 20k on it, chances are very good that it's original. When they went out under the warranty period, Dodge removed it and installed the pumps in the tank. If you can see the pump on the filter housing, it's sure to be original.
Since you have this pump...replacing it is not very difficult and does not require a draw straw at all. I replaced my filter mounted pump recently as a precautionary measure. I purchased a Raptor 100 from Lary at the DTR store and am very pleased with the great service Lary provides. The Raptor 100 is capable of supporting up to 500 hp. Raptor 100 and the 150 series pumps connect to the stock fuel tank sending unit and the rear of the filter housing. They do not require the fuel tank to be dropped in order to perform the install.
Old Feb 2, 2012 | 08:13 PM
Spooler's Avatar
Get the Airdog 100 and you won't have to worry about the draw straw. It will supply plenty of fuel for you.
Old Feb 2, 2012 | 08:36 PM
Dr.Dizzle's Avatar
I have attached a copy of the stock fuel pump location from the service manual. I hope you find this helpful!
http://https://www.dieseltruckresource.com/forums/attachment.php?attachmentid=32592&d=1273451807
53 willys
38
Nov 6, 2008 11:18 AM
Hintz
38
May 22, 2008 08:28 PM
O.T
Apr 23, 2008 11:08 PM
goose2w1
Feb 29, 2008 08:45 AM
84mphcdt
16
Dec 19, 2007 11:31 AM
