ran out of fuel NEED HELP! Cant start
Old Mar 30, 2005 | 06:29 PM
dyeager's Avatar
Unhappy ran out of fuel NEED HELP! Cant start
Ran out of fuel, primed lift pump but still can't get it started
Old Mar 30, 2005 | 06:34 PM
RCW's Avatar
RCW
Since there is no information about the truck, the best bet is for you to read your owner's manual section on changing the fuel filter. Start there, and then if it does not do the job, let us know which year you are having trouble with.
Old Mar 30, 2005 | 06:45 PM
phox_mulder's Avatar
Yes, the year would help immensely.
Since you said you "primed the lift pump" this implies a 12 valve engine, but unsure.
phox
Old Mar 30, 2005 | 09:53 PM
mr T's Avatar
gives us info on your truck! and what u did and we can help
Andrew
Old Mar 30, 2005 | 09:54 PM
Hemi Cat's Avatar
Did you put #2 diesel in the tank before you tried to start it and prime it??? Did you open the bleeder screw on top of the filter housing and by the overflow valve? Like the rest said, what are you driving??? If it's a ford........
Old Mar 31, 2005 | 09:13 AM
infidel's Avatar
No, it's a Honda moped
Old Apr 5, 2005 | 11:08 PM
demsmiths's Avatar
crack the fuel lies one at a time turn engine over till fuel starts spraying,will usually start after doing this make sure there is fuel in filter assy.
snowmanx
May 31, 2019 03:37 PM
jefe4x4
25
Dec 15, 2011 07:33 AM
Deadbunny
Mar 29, 2009 10:17 PM
zero2zero
Apr 13, 2007 10:30 PM
Buckshotmckee
Jun 10, 2005 12:23 PM
