Ram 2500 Shutters on Take Off
Old Aug 21, 2010 | 08:16 AM
rjrjrusa's Avatar
My Ram 2500 Mega Cab shutters from a take off. It is not wheel hop or anything else that can be easily seen. I put a 6" lift and track bars and it got better but the shutter is still there. If I am rolling and then take off no shutter. Shutter is also present when the truck down shifts going up a hill when power is applied. Anyone got any ideas ?
Old Aug 21, 2010 | 09:19 AM
sheriffav8r's Avatar
I'd personally go back to the dealer and have the PCM reflashed. Sounds like the electronic controller is hiccuping or something. My wife's Jeep Patriot did that and it was driving me crazy. Had it reflashed and now it worky real good....
Old Aug 21, 2010 | 11:54 AM
DirtEater's Avatar
By shudder, are you talking about axle wrap? Sounds exactly like what side effect a 6" lift would cause.
Old Aug 22, 2010 | 05:41 AM
rjrjrusa's Avatar
The PCM has already been flashed and did not help and No its not axle wrap as it was present before the lift and the lift and track bar actually made it better.
Old Aug 22, 2010 | 09:29 AM
Big iron dave's Avatar
Mine does the exact same thing and i have a 4" lift.My 07 also had it with no lift..I noticed it right from the test drive...guess i'm used to it from my 07.I did enquire about it and i was told it was because of the lift...YA RIGHT...LOL..
Old Aug 22, 2010 | 09:56 AM
browndg's Avatar
I had the same issues, tranny was slippen. replaced tranny with built tranny, problem solved.
Old Aug 22, 2010 | 10:29 AM
orenlasko's Avatar
Launch shudder...
Do you have a two piece driveshaft? I had this exact problem in my 07 mega dually. Shimmed it checked angles etc. It is unfortunately normal. I did eventually cure it with a one piece driveshaft from Chrysler. Check through the earlier generation threads under launch shudder.
Cheers
Old Aug 23, 2010 | 10:12 AM
75woody's Avatar
I'd check the rear drive shaft. Both me and my bro had the same issue when we added a 6" lift. I fixed mine by shimming the tranny mounts to lessen the angle. He fixed his by installing a one piece drive shaft. Both of our trucks were '06's though.
Donut Gestapo
Sep 19, 2010 10:12 PM
OLBLUE02
Aug 27, 2010 11:27 AM
wrangler
Mar 26, 2008 05:43 PM
flashgordon
Oct 5, 2006 04:26 PM
Buckshotmckee
Dec 23, 2004 07:07 PM
