Rail pressure w/ Edge EZ...
Old Aug 9, 2007 | 04:28 AM
Dodgezilla's Avatar
Anybody have this info on a 600? The Puck gets up to 27000 easily and I'm just wondering if the EZ may be a little less....
Old Aug 9, 2007 | 11:54 AM
enafzige's Avatar
I've had mine off for a while now, but I did a test one day cruising on the highway, steady throttle, level ground at about 80 mpg.
Level 1 gave ~ 22,500
Level 2 gave ~ 25,000
Level 3 gave ~ 27,000
I was using a DiPricol Optix Rail Pressure gauge for the measurements.
--Eric
Old Aug 9, 2007 | 01:24 PM
Dodgezilla's Avatar
Thanks Man! Looks about the same since the low setting on the Puck is about the same as level 3 on the EZ....
Old Aug 9, 2007 | 02:54 PM
Justin26's Avatar
Dodge on the stack you are running you have the Diablo downloader and the puck right. What settings do u run them on. I was just curious? I run mine on crazy larry and the edge on level 1 for my setup.
Old Aug 9, 2007 | 05:59 PM
Dodgezilla's Avatar
When I'm running the Predator I don't even use the Puck because it has programs that already add pressure. Adding the puck to that doesn't really seem to make much of a difference. Using the puck with the Stacker tunes makes a difference but only because the stacker tunes add no pressure.
Old Aug 9, 2007 | 08:32 PM
973604x4's Avatar
EZ's keep the RP in safe levels. I've watched with my rail gauge.
a rail gauge is a MUST HAVE on a common rail!
Old Aug 9, 2007 | 10:54 PM
Justin26's Avatar
Hey Phil I was thinking about getting the rail gauge. How does it hook up. Does it just plug in somewhere like the ez or what. Just wondering how hard it is to install and if I need it.
Old Aug 9, 2007 | 10:58 PM
973604x4's Avatar
1 plug in the rail harness...and the usual wiring for light
Old Aug 9, 2007 | 11:08 PM
qzilla's Avatar
Depends on which rail gauge you get.
Our little digital one is a simple plug and then power and ground. No light wiring needed.
Old Aug 10, 2007 | 04:20 AM
Dodgezilla's Avatar
Yup. The Quad Rail Guage is stupid simple to install........
klx650a2
Aug 12, 2009 12:17 PM
5POINT9
Mar 6, 2009 11:34 AM
5.9Excursion
Mar 13, 2008 10:56 AM
Hoss
16
Sep 7, 2006 07:36 PM
Rod meyer
Feb 19, 2005 04:21 AM
