question about twins
Old Apr 27, 2010 | 01:04 PM
firgod4's Avatar
im looking at putting twins on my truck, im gonna be getting a transmission ordered here within the next month and i want to do a few things while i am under the hood so to speak, i wanted to know is there a setup to run twins using my stock turbo as one of them and if there is what other mods would i need to have to make it run right/good injectors etc., the mods i have right now are the ones in my signature, any help would be greatly appreciated.
thank you
chris
Old Apr 28, 2010 | 10:10 PM
firgod4's Avatar
come on guys nothing?
Old Apr 29, 2010 | 07:35 PM
lvmknsmoke..'s Avatar
im not much of a 12 valve guy but i do know there are kits i think maybe source auto has 1 that uses the stock turbo and uses a s400 or htb3 underneath. if you want some serious power your gonna want some 100+ hp injectors. maybe even 150s. and head studs too!
Old Apr 29, 2010 | 07:47 PM
HOHN's Avatar
Source Automotive is your best bet for twins kits that reuse the stock charger, imo.
Old Apr 29, 2010 | 08:12 PM
8UPRACIN's Avatar
Give Bill or Rip at Source Automotive a call. My first setup was a HX35-S400 setup and it spooled quick for a small setup and handled my EGTs great. You can always buy a newer hotpipe later on for your setup from them if you decide that you wanta run a larger turbo over the S400. They are great guys to deal with and have some VERY SICK trucks!!!!
Old Apr 29, 2010 | 08:33 PM
firgod4's Avatar
wow thanks guys, yea i was thinkin about 100 or 150 injectors but do u think i will need the studs? i thought u needed studs if i bumped the timing or if i put a whole lotta boost, and how well is that gonan run i know u said the egts were good and it spooled good but how good is it and is it gonan be worth the money?
Old Apr 29, 2010 | 08:43 PM
8UPRACIN's Avatar
Anything over 45psi of boost you wanta stud. I ran 50 but it was pushing it. They are a good investment otherwise you gotta pull the head and replace the gasket and its not too fun. I still am running on my stock gasket somehow with studs and haven't blow one yet. With the twins your boost is going to be higher than 45 unless you really wastegate it off and run small injectors. Best to put them in cause you are really gonna like the higher boost!!
Old Apr 29, 2010 | 08:47 PM
firgod4's Avatar
oh ok idk then i dont think im going to have enough $$$$ to do all of those (injectors,studs,and twin kit)all at once but im gonna have to do some more price checking, im think im only gonna have around 1800 to do my stuff after i get my tranny so idk
Old Apr 29, 2010 | 08:58 PM
firgod4's Avatar
what kind of price do u think im looking at for this stuff i know i can always get the 370 marine injectors, but what is your best onion for a setup
Old Apr 29, 2010 | 09:13 PM
DodgenIt's Avatar
Your pretty limited on the 1800$.
IMO, head studs are a must for twins. If you have em wastegated to 45 lbs, you arent gonna get the avalible power twins offer.
You'd be better off goin with a combo like a HX-35/40 hybrid or s300, and some Mach 1.6 or DDP 3's.
That way you will have a turbo and injectors that compliment each other, and not have to worry about head studs and still get a Very nice power boost.
Just my .02.
Old Apr 29, 2010 | 09:15 PM
firgod4's Avatar
u think i could do the ddp3's with a s300 turbo for that amount of money?, and how much boost will that put me at and where would u reccomend buying these items?
Old May 5, 2010 | 09:32 PM
Mike Holmen's Avatar
The Guru
I would tweak your pump for more fuel first? Which governor springs you have? Put in 191's or laser deliver valves. Have you adjusted the AFC for more travel? Push the plate fully back toward the firewall. If you don't have a 215HP 5 speed 12v, you could also use a rack plug so you have abit more fuel. Adjust the barrells, for more fuel. An aftermarket camshaft and valve springs would wake up the motor decent with a cam. I would run a S475 for the primary and build you own twins. Just remember to port out the wastegate for better flow or put in an external gate. The stock turbo will limit top end power. Benching the pump for max cc's is also a good idea. 4gsk or 5 gsk for the governor springs. You might have to adjust the throttle stops some so you can get max rpms.
Old May 5, 2010 | 10:58 PM
firgod4's Avatar
i have the 3gsk,and no i havent done anything with the afc housing i am unsure about how to go about that, and what does that do? i thought u pushed the plate toward the front end to give more fuel, or was that your point? no i have the 12 valve auto but its a built auto(in the process anyway),how do i adjust the throttle stops also?
Old May 5, 2010 | 11:31 PM
capt.Ron's Avatar
I think I can... I think...
hmmmm
Twins using my stock turbo in the set.
So if I go with studs, the twins, and a 3000gsk kit what turbo and injectors could I add that will give me good spooling and still allow me to tow my 15K fifth wheel?
Sorry firgod4 didn't mean to highjack you thread.
Old May 6, 2010 | 05:09 PM
The Guru
These guys probably make the best 12v or 24v injectors for the price.
http://www.southerndieselx.com/index...y&path=309_310
Contact Harry at Peak for fueling tweaks or CDS (columbus diesel service)
http://www.peakdieselperformance.com..._Upgrades.html
For twins questions, ask away. The stock turbo will be ok, you'll have some egt's depending on fueling. I would open up the wastegate on the stock turbo. The stock turbo will limit top end power. I like both the BTH-3B/26 and S475/1.32 for primary. They are cheap but work nice, some guys like more expensive primaries. I like to build-up cheap stuff first. I would have the wastegate open around 20-26psi to start with, that helps to lower egt's but allowing the primary to spool-up.
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
dodgediesel
17
Apr 5, 2011 11:21 AM
Stock 02
28
Sep 24, 2006 11:09 AM
stlsparky
Nov 21, 2005 10:02 PM
