Putting sport bumper on non sport
Old 03-11-2004, 04:21 PM
Muted User
brianflynhigh's Avatar
I have an 02 and would like to put on the Sport front bumper if I cam find one used. has anyone done this? If so how hard was it? Thank you
Old 03-11-2004, 05:55 PM
GlennRMK's Avatar
Only thing is that you need a grille as well, if you going to run the 99 and newer style Sport front end.
You could use a 98 Sport bumper with your current grille however.
Also, beware the Sport bumper is more fragile. My buddy cracked his pretty good on his 01.
Old 03-12-2004, 10:23 PM
Rhino's Avatar
You do not have to replace the chrome grill when going to a 99+ sport bumper. The 99+ sport bumper and chrome grill will fit without interferrence. You may however want to also install a 99+ sport grill to complete the sport look. The choice is yours.
Old 03-14-2004, 12:10 AM
GlennRMK's Avatar
How do you figure?
From the looks of it, the Sport grill dips down lower.
So, if you used the non-Sport chrome grille, you would have a gap between the bumper and grille.
Old 03-14-2004, 07:05 AM
Rhino's Avatar
You are correct. The Sport grill does dip down to follow the lines of the Sport bumper. It does leave a slight gap between the bumper and the grill but it is not all that noticable. I know of a few guys running around with a non 99+ Sport grill on a 99+ Sport bumper. A couple didn't want to pay the big $$$ for the 99+ Sport grill, while others just preferred the look of the chome.
The reason I posted was because I read your first post to mean that the bumper would not fit w/o the grill. I just wanted to mention you can install the bumper w/o the grill.
Also this applies to 98 and newer trucks only. The 99+ Sport grill will not fit 94-97 trucks that have AC without some modfications.
I have attached a pic of an 01 Sport with a non Sport grill.
Old 03-14-2004, 03:19 PM
GlennRMK's Avatar
Hmmmm
Your right
Doesn't look too bad.
I like the sport grille personally.
Old 03-14-2004, 04:14 PM
doodah's Avatar
or just find somebody that wants to swap bumpers and grills all together like me! only a 97. with 99 grill and bumper
Old 03-14-2004, 05:24 PM
Rhino's Avatar
doodah,
Does your truck have AC. I found that on 97's the AC Condensor gets in the way of the grill and grill bracket.
Old 03-14-2004, 08:08 PM
doodah's Avatar
it did not get in the way, and yes my 97 has air- had air I do not own this truck no more. I bought a 98 gasser sport. didnt need torque as much as I needed the money. I really miss that truck i switched the grill with a guy from PENN. and bolted it it right up worked fine. bumper bolted right up to frame cause it came with the brackets on it.go into my gallery I think I got pix of it before paint
Old 03-14-2004, 09:00 PM
Rhino's Avatar
Thanks.
Hmmm...There must be the two different styles of AC condensors in 97. The one I had worked on had the older style of lines/brackets and they will not allow the 99+ Sport grille to fit without modfications.
I was certain the bumper brackets were the same. 97 was the first year of the new bumper bracket holes. For others reading this, the 99+ Sport bumper brackets need to be modified to fit 94-96 trucks.
Old 03-15-2004, 12:59 AM
1320's Avatar
I have a black 02 sport bumper and grill......gen 3..... Anybody know if it will go on a 98 12 v?
I figure the grill wont but the bumper might......and then get the 99 style sport grill.....
I just want a red sport front end on my 98........
I d sell the 02 gen 3 stuff too.....
Old 03-16-2004, 05:12 PM
pro puller's Avatar
The 02 gen 3 stuff off a 1/2 ton sport?
Old 03-18-2004, 10:50 AM
1320's Avatar
yes.
Old 03-19-2004, 01:33 AM
BigBlue's Avatar
Something I've been wanting to do is paint just the outside of my grill and leave just the center section chrome. I've seen a couple of 03's with just the outside ring painted and the bumper painted and I think it looks down right awesome.
Old 03-19-2004, 01:48 PM
Cumminsdude's Avatar
got pics?
1badchopper
07-02-2009 09:18 AM
hipsi
07-15-2007 01:00 PM
airplaneman00
13
06-22-2007 09:20 PM
B.Law
07-18-2006 02:46 PM
mamm7215
07-15-2004 08:08 AM
Quick Reply: Putting sport bumper on non sport
