Sport & Non Sport Model Headlights
Old Jul 12, 2007 | 12:06 AM
hipsi's Avatar
I was looking at a set of healights for a 2001 sport online, it appears they have two beams inside? Is this something I can swap over to my truck or is the harness different?
I plan on putting a sport bumper & Grille on over the winter
Old Jul 12, 2007 | 07:25 AM
patdaly's Avatar
Do a search here, there is a kit to add the second bulb, the lights bolt right in.
Looks like a good upgrade.
Old Jul 12, 2007 | 10:46 AM
cLAYH's Avatar
I've got the the Sport lights, there is an extra bulb as well as an extra fuse for it the the panel so I'm sure soem extra wiring migth be needed. Your truck might already have it and jsut need the pigtail upto the lamp unit for it.
Old Jul 12, 2007 | 09:19 PM
dssimecek's Avatar
You might be lucky and have the wiring already in for the sport. Look close. If not look on here there is a lot of information on lighting. Most kits come with relays and all the wiring needed for the conversion.
When you get it done please post the information.
Old Jul 12, 2007 | 11:10 PM
Tate's Avatar
http://www.danielsternlighting.com/p.../products.html
About 1/3rd of the way down.
Old Jul 13, 2007 | 12:54 AM
hipsi's Avatar
Thanks guys
Old Jul 13, 2007 | 03:07 AM
wcbcruzer's Avatar
You'll also need to cut a piece of metal behind the headlight to get the sport headlights to fit.
Old Jul 13, 2007 | 08:34 AM
DL1221's Avatar
On an 01, the socket wiring for the extra two bulbs is already there from the factory. The socket harnesses are tucked up and secured behind/under the headlights, tied to the fender. You just need to pull the sockets out from the dummy plastic plug they are in. The sport headlight assembly just bolts right in, no sheet metal trimming required. But you may need to buy the sport light relay and fuse that are in the fuse box next to the battery. Oh, and you'll need the turn signal corners too, they are different for the sport lights.
On a 96, there is no factory harness for the extra bulbs, so you'll need to buy one or make your own and you'll also have to trim the sheet metal so that the two extra bulbs will clear.
Old Jul 15, 2007 | 01:00 PM
FDC's Avatar
FDC
Originally Posted by Tate
That price is less expensive than other pre made harnesses I've seen. Not bad. My 01.5 did not have a factory harness for sport lights, so I had to buy the harness---I was too lazy to make one.
It's certainly worth the upgrade.
cmac
112
Jul 27, 2013 07:48 AM
Turbinator
Aug 30, 2007 09:37 PM
B.Law
Jul 18, 2006 02:46 PM
mamm7215
Jul 15, 2004 08:08 AM
brianflynhigh
14
Mar 19, 2004 01:48 PM
