pulsating power steering
Old 04-27-2007, 06:28 PM
suprajake's Avatar
I did a search but didn't find my exact symptoms.
My truck is STOCK, STOCK, STOCK, 04.5, 78K, 4wd, city driven. The power steering has worked fine until yesterday. It steers left and right just fine, until I release the steering wheel after a cut, while moving. As the steering returns to neutral, it pulses (jerks). Same problem in either direction.
No leaks, fluid level is good, cap vacuum seals to reservoir, no odd noises. No unusual tire wear or wobbly ball joints. The truck is tight. I'm pretty smart at times... but it seems like some type of directional return fluid valve in the box is stuttering.
Anyone have any insight?
Old 05-08-2007, 04:51 PM
BLACKBIRD8200's Avatar
I'm having the exact problem you are. I've checked everything and can't come up with anything. Have you found what the problem is? If so please share.
Old 05-08-2007, 08:18 PM
Anyone out there know what this could be?
Old 05-08-2007, 10:01 PM
wreedCTD's Avatar
is asking the dealer out of the question?
Old 05-08-2007, 11:29 PM
CatDiesel_762's Avatar
Check the Dodge TSB Site http://dodgeram.info/tsb/index.html. I think there are some TSB regarding the steering systems and a hose dampner might be needed.
Shawn
Old 05-09-2007, 12:09 AM
Fisherguy's Avatar
A friend had the problen on his 04, he said the PS cap was loose or on wrong or something, fine now...
Old 05-09-2007, 12:41 AM
Coal Train's Avatar
I have an 04.5 and had the very same thing, but my fluid was a little low, I put Lucas fluid in it and it stopped.
JVDodge
01-28-2010 04:44 PM
EZGO1992
11-22-2008 10:23 PM
sammy340
10-22-2004 01:25 PM
sneilan
08-15-2004 09:33 AM
vtailflyer
08-04-2004 11:31 AM
Quick Reply: pulsating power steering
