pulsating power steering
Old Apr 27, 2007 | 06:28 PM
suprajake's Avatar
I did a search but didn't find my exact symptoms.
My truck is STOCK, STOCK, STOCK, 04.5, 78K, 4wd, city driven. The power steering has worked fine until yesterday. It steers left and right just fine, until I release the steering wheel after a cut, while moving. As the steering returns to neutral, it pulses (jerks). Same problem in either direction.
No leaks, fluid level is good, cap vacuum seals to reservoir, no odd noises. No unusual tire wear or wobbly ball joints. The truck is tight. I'm pretty smart at times... but it seems like some type of directional return fluid valve in the box is stuttering.
Anyone have any insight?
Thanks
Old May 8, 2007 | 04:51 PM
BLACKBIRD8200's Avatar
I'm having the exact problem you are. I've checked everything and can't come up with anything. Have you found what the problem is? If so please share.
Old May 8, 2007 | 08:18 PM
Anyone out there know what this could be?
Old May 8, 2007 | 10:01 PM
wreedCTD's Avatar
is asking the dealer out of the question?
Old May 8, 2007 | 11:29 PM
CatDiesel_762's Avatar
Check the Dodge TSB Site http://dodgeram.info/tsb/index.html. I think there are some TSB regarding the steering systems and a hose dampner might be needed.
Shawn
Old May 9, 2007 | 12:09 AM
Fisherguy's Avatar
A friend had the problen on his 04, he said the PS cap was loose or on wrong or something, fine now...
Old May 9, 2007 | 12:41 AM
Coal Train's Avatar
I have an 04.5 and had the very same thing, but my fluid was a little low, I put Lucas fluid in it and it stopped.
JVDodge
Jan 28, 2010 04:44 PM
EZGO1992
Nov 22, 2008 10:23 PM
sammy340
Oct 22, 2004 01:25 PM
sneilan
Aug 15, 2004 09:33 AM
vtailflyer
Aug 4, 2004 11:31 AM
