Power window issues
Old 08-09-2005, 01:27 PM
TxDiesel007's Avatar
Angry Power window issues
Guys i dont like power accessories
at all, for the reason taht my power window on the passenger side of the truck only works when it wants to, from either switch, the driver door control for the passenger switch usually never works anymore and the passenger one after some dinking around with it, at times ill get lucky and both work, any ideas what could be the culprit for my lousy windows?
Tx
Old 08-10-2005, 06:03 AM
robert chilton's Avatar
dirty contacts in the switch. Also both switchs work together so one acts as a master switch. If memory serves me right the passenger side switch runs to the drivers master then back to the window motor. Is you are electrically inclined it is the same principal as 2 switchs controlling a lightbulb in your house. A look at a wiring diagram shoul let you figure which is the master. You may be able to clean it or it may just need to be replaced. I dont know how crysler designed the switch. Good luck.
1991.5 mopar
01-27-2017 11:07 AM
Rednecktastic
08-29-2010 11:26 PM
raven392003
10-29-2007 11:39 AM
jgiachino
07-13-2007 09:19 AM
TxDiesel007
10-13-2005 08:37 AM
Quick Reply: Power window issues
