Power Wagon Motor Mounts
Old Apr 8, 2011 | 09:23 PM
Mike Mc's Avatar
My '68 power wagon has a '93 Cummins in it. I currently have the cab and engine out for some up grades. One of the up grades is switching from a 10 speed to a 47RH transmission. The ten speed has mounts at the bell housing that support most the engine and tranny weight and easily handle the torque.
Since I have the engine out should I upgrade to 2nd generation motor mounts? Or will the first generation mounts handle the heavy towing that I plan on doing for years to come?
The engine is only turned up a little bit.
Thanks,
Mike
Attached Thumbnails Power Wagon Motor Mounts-cab-off-up.jpg   Power Wagon Motor Mounts-misc.-pics-004.jpg   Power Wagon Motor Mounts-doubles-micks-2010.jpg
Old Apr 8, 2011 | 09:37 PM
huntinguy's Avatar
I love this truck!!!
Old Apr 10, 2011 | 09:11 PM
Mike Mc's Avatar
Anybody have any bad experiences with the '93 motor mounts? If so I'll change them out while I have it apart with the newer styles.
Thanks M-
Old Apr 11, 2011 | 02:34 PM
bgilbert's Avatar
2nd gen mounts are superior to the 1st gen mounts. If you have the ability to fab them in, by all means, go to that style.
Old Apr 11, 2011 | 10:13 PM
Mike Mc's Avatar
Thank You Sir! Thats all I needed to be convinced to change them.
I can easily fab new frame mounts to hold the 2nd generation engine mounts but will they bolt up to the '93 block with no troubles?
Old Apr 11, 2011 | 10:15 PM
307Kenworth's Avatar
I've seen this truck on HEF I think and now on here. I like this rig man. Hope to do something real similar with my '60 one day.
Old Apr 11, 2011 | 10:26 PM
Mike Mc's Avatar
I found some 98.5-02 24 valve motor mounts for $65 will they bolt up?
Thanks 307, I drive the truck regularly but the woman still hasn't figured out the ten speed.... I figure if she hasn't figured it out by now she's not going to. So I'm putting a 47RH auto in it so she can drive it too. I'll miss the ten speed for a little bit.
Here is a couple video's
http://www.youtube.com/watch?v=Neh0wrBjVn8
http://www.youtube.com/watch?v=0Sgxb...eature=related
I'm going to leave the low-direct-high Brownie box for more gear options.
Old Apr 12, 2011 | 07:47 AM
bgilbert's Avatar
Yes they will bolt to the block no problem. It's basically the same block from 89-02+-.
Common
Jul 21, 2006 10:03 AM
Underpsi
Jul 13, 2006 08:54 AM
Ridgetop
Mar 4, 2006 04:58 PM
Casket Man
Jan 17, 2005 03:47 PM
Haulin_in_Dixie
May 5, 2004 01:23 PM
