Possibly Draging Brakes
Old 11-22-2009, 11:08 AM
Jeff5886's Avatar
When I hit the brakes on my truck, the brake lights stay one for about 3-5 seconds after I release the brake pedal. I am wondering if this is causing my brakes to continue "braking" when I let of the brakes. Anyone ever seen anything like this or know how to fix it?
Jeff
2000 Dodge 2500 Sport Cummins 24 Valve, 4x4, Auto, Quad Cab, Short Bed With BHAF, Airdog 100, Edge Juice with Attitude, Pioneer DEH-6100BT, Turbo Silencer Removed, Viper Remote Start, ATS TQ Converter, Upgraded Input Shafts, Shift Kit, Lots More!!!
Old 11-22-2009, 11:18 AM
CarlJensen's Avatar
You might have a caliper hanging up or a bad brake line, if in fact, it is hanging up. It may just be the brake switch. Do you have an IR gun? Checks temp at each wheel. It will show a hanging brake right away.
Old 11-22-2009, 11:20 AM
Jeff5886's Avatar
I can get one, how would I use it?
Old 11-22-2009, 11:25 AM
CarlJensen's Avatar
Run the truck up to speed a couple of times and brake to a stop. A hot wheel indicates a problem. This also works at finding a bad bearing. Aim the heat gun at the center of wheel, not the tire.
Old 11-22-2009, 11:28 AM
CarlJensen's Avatar
Those IR guns are handy. I used one on my fiver to spot heat leaks for winter living in it.
Old 11-22-2009, 07:09 PM
SIXSLUG's Avatar
Sounds to me like your brake light switch may be out of adjustment. I don't think the brake pressure has anything to do with the electrics that trigger the brake lights if you are talking about the taillights and not the brake indicator light on the dash.
Kurt
Old 11-23-2009, 06:17 AM
CarlJensen's Avatar
Sixslug is right. Check the easy stuff first. The switches do go bad, are inexpensive and easy to replace.
Old 11-23-2009, 11:34 AM
01RAMer's Avatar
The only thing that activates the brake lights is the brake light switch down at the brake peddle. New ones has the switch plunger fully seated and after installation, you push a button to make the switch pop out to touch the peddle arm (self adjusting). Make sure you don't have the peddle pushed in at all when you set the switch or it will be out of adjustment.
05 Ram 3500 SRW
05-01-2011 09:14 PM
Forrest Nearing
61
03-31-2008 12:03 AM
wildcargo
11-29-2005 04:20 AM
Dodgezilla
10-12-2005 04:28 PM
ATEAV8GN
01-26-2003 02:49 PM
Quick Reply: Possibly Draging Brakes
