Parking brake adjustment on dually
Old 04-30-2007, 02:48 PM
skinny2's Avatar
Hello, just wondering if anyone had any pointers on how to adjust the parking brake on my '03 dually. Slowly getting less effective which isn't good with a 15,000# trailer out back. Just crossed 108k miles and all brakes are in great shape so I'm assuming it's in the drum part of the parking brake (if i understand how these work correctly.....). Thanks for any info.
Old 04-30-2007, 08:55 PM
doorguy's Avatar
Yes the parking brake are drum style , to adjust , raise the rear of vehicle so you can rotate the wheels.
Remove the rubber plug from the access hole in the brake support plates(middle bottom)
insert adjusting tool through support plate access hole and engage tool in teeth of screw star wheel
Rotate adjuster screw star wheel (move tool handle upward) until slight drag can be felt when wheel is rotated.
Back off adjuster screw star wheel until brake drag is eliminated.
Repeat for opposite wheel
Old 05-01-2007, 06:37 AM
skinny2's Avatar
Thanks for the info. I'm going to crawl around and work on this first chance I get.
bulldog_bones
09-09-2009 01:53 PM
ratlratl
11-08-2007 10:12 PM
CumminsRedneck
08-27-2006 08:51 AM
Pete Miller
12-22-2005 07:45 PM
ldornak
04-03-2005 09:48 PM
Quick Reply: Parking brake adjustment on dually
