Orfice???or no orfice???
Old 07-18-2011, 10:18 PM
whosdunit's Avatar
My a/ac don't cool but , my compressor sweats like its raining.LOW side @ 55-60---HIGH side @ 125-150----sandin comp., whats stuck in comp???? Some one told me there was a orfice in the line from the comp., to the condenser and it is stoped up or dirty --yes or no ???
Old 07-19-2011, 05:18 AM
jogl's Avatar
See anything in the sight glass?
Old 07-19-2011, 07:11 AM
whosdunit's Avatar
Bubbles!!!!
Old 07-19-2011, 07:28 AM
Hvytrkmech's Avatar
High side pressure is perfect, low side a tad high. usually when an orifice tube plugs pressure on the low side is higher. have you ever changed the receiver/dryer?
Old 07-19-2011, 08:23 AM
whosdunit's Avatar
The po put anew 1 on, it's clean,,,,i put on new exps-valve,cleaned,flushed 2 times!!!! Right now everything points to the comp., been trying find info.,on comp., so i can repair. thanks HVY..
Old 07-19-2011, 08:25 AM
torquefan's Avatar
First gen trucks have an expansion valve instead of an orifice tube.
Old 07-19-2011, 09:38 AM
1st Generation Admin
BC847's Avatar
Those numbers look about right for an engine that's idling. You might see the suction pressure drop to around 35psig at a higher engine rpm.
The suction line sweating at the compressor is normal operation (the cooling effect is needed to cool the compressor).
Based on what info is provided thus far tells me the refrigeration system is working overall.
You might be a little short of refrigerant (we don't know what the outdor air temperature is at your house to confirm via a refrigerant pressure/temperature chart ).
If this were my mess, I'd look hard at the dampers of the blower box and make sure they're working correctly.
* If the refrigerant metering device, be it cap-tube, TXV, etc, were restricted, you'd see the suction pressure abnormally low with little or no sweating at the compressor.
Old 07-19-2011, 11:39 AM
dguru's Avatar
Clamp off the heater hose and see what happens. Or you could install a valve in the heater hose.
As stated above it sounds like a control problem. I don't remember if 1st gen has cables or vacuum controls.
Old 07-20-2011, 10:24 AM
enydick's Avatar
ac parts house has great deals on compressors 166 shiped one year warrenty
Old 07-21-2011, 09:28 AM
whosdunit's Avatar
enydick,, thanks ,is this price for new,or reman.,?????i could use the web site........
Old 07-21-2011, 03:59 PM
Aquah0lic's Avatar
http://www.acpartshouse.com
ckennedy
08-13-2015 07:35 AM
Katmandu
07-22-2006 12:17 PM
Quick Reply: Orfice???or no orfice???
