Ok time to order....
Old 11-12-2003, 07:17 PM
Bulldozer's Avatar
Well I've bugged Rod enough. Time to order I pull fairly heavy often,cattle hay etc. Have 29,000 miles on truck and want reliability and a power upgrade. I know I'm my own warranty. So what do you think PM3 max flow southbend clutch and eventually EDM's (probably 2's or 1.5's) or EZ,EDM's max flow and clutch? I want a solid Upgrade and I believe Rod totally and will be making my own decision but just would like to hear what you guys had to say. Thanks alot Jake
Old 11-12-2003, 07:19 PM
Bulldozer's Avatar
Re:Ok time to order....
Well I need moved sorry thought I was in Hi per. sorry :
Old 11-13-2003, 03:55 PM
GatorRam's Avatar
Hey Jake,
I just put in some 1.5 EDM's and with the box off they act the same as my old EZ EGT wise but with a little more grunt in the low end. I haven't towed with them yet but I did tow with my EZ a little and it was great. I know that the two don't exactly work on the same principle but I don't think you'll have a problem. I'm not familiar with the PM3 box but on my drag comp you can dial the fuel back on each of the five settings if you see something you don't like. In my opinion if you have the means to do it go ahead and get the fueling box because you can cut it back for towing and turn it up when you feel like playing around. If you don't do it now you'll probably end up doing it in the long run anyway.
Adam
Hairy1
04-05-2011 09:16 PM
sheriffav8r
10-24-2010 08:36 PM
jmccart
08-02-2007 12:35 AM
dealseeker
15
12-17-2002 06:43 AM
commonrail
10-30-2002 04:56 PM
Quick Reply: Ok time to order....
