oil preasure ?'s
Old Apr 9, 2006 | 01:29 PM
acook's Avatar
oil preasure ?'s
Ok guys, on my 90 what should the oil preasure run at? when it is warmed up it is right at the bottem line, not the one right next to L but the bottem line in the middle section(3 or 4 lines) and when i am driving it moves up to the next line, so it is never over 1/2, is there something wrong or is this normal? i know my friends cummins run higher but there 2nd gen's
robert
out
Old Apr 9, 2006 | 01:34 PM
Begle1's Avatar
That's how mine works, and as far as I've heard, that's where they were at off the lots.
Then again, I don't know how accurate that gauge really is... The needle might just stay in the same location for anything over 30 PSI.
Old Apr 9, 2006 | 01:37 PM
edwinsmith's Avatar
On my 89 that's where it sits. That was after I changed the bad sensor. From what I read here the only way to know what your oil pressure really is, is to install a proper calibrated gauge.
WD said that any pressure is enough for the Cummins. Mine went down a tick when I switched to Mobil1 Truck/SUV oil but I hope it gets a little better mileage. It starts easier in the cold also.
Edwin
bgilbert's Avatar
Wipe your butt with the factory gauges. They are worthless. The marks don't correlate (sp) to nothing. If you want to know numbers, get yourself some aftermarket gauges, with numbers.
Old Apr 9, 2006 | 02:08 PM
G1625S's Avatar
Yup, factory gauges are a rough approximation at best. I replaced my oil sender and it got better, but it's slowly getting lower. I finnaly plumbed a mechanical gauge into the same port that the factory sender is in, results: pegged the 100psi gauge when cold, 65psi cruise and 38psi hot idle. I don't watch the dash gauge anymore.
Old Apr 9, 2006 | 02:13 PM
I think there was a "usually" or a "fortunately" in there somewhere.
However, if the stock gauge is showing pressure, you are OK. If not, it's likely a bad sender. Oiling system problems are very uncommon on these trucks.
Old Apr 9, 2006 | 03:16 PM
acook's Avatar
thanks guys, i was just a lil worried, like i said i have all fords and am new to dodges so didn't know if there guages were any better than fords junk guages.
robert
Old Apr 9, 2006 | 03:22 PM
EClancy's Avatar
Wow, you get good oil pressure!
My '92 usually is about 75-80 cold, 50-55 driving around at 50mph, and about 30-35 hot low idle.
I got a cheap guage at walmart and seems to do the trick, as my factory guage was junk when i bought the truck.
l jobb
Jan 31, 2008 10:27 AM
charliex25
Aug 11, 2006 04:35 PM
jt
Mar 22, 2004 07:36 PM
thumper 549
Oct 27, 2003 02:50 PM
kingofdodge7131
Mar 29, 2003 04:12 PM
