o-ring head?? Specs/materials
Old Jun 19, 2010 | 06:52 PM
DNRCustoms's Avatar
I was wondering if any of you guys new the specs on o-ringing a head? Like the diameter of the ring, depth/width and what is used for the ring. Im thinking of having my Grandpa's Machine shop do it. Never done it, but my uncles are the **** when it comes to machining. I would rather give them the money, Also, can u use a stadard marine head gsk?
Old Jun 20, 2010 | 11:38 AM
Ahineman's Avatar
I had my head done by PowerParts Engineering, so I don't know all the specs. But I know they used .042" wire. Fire rings take a special gasket, but o rings don't. I'm using a .020 over marine gasket with my o rings.
Old Jun 20, 2010 | 12:14 PM
JD730's Avatar
I just posted an answer to this same question about a week ago.
I use the stock gasket or a thick one depending on what I'm doing. They shouldn't have any problem doing it. I've done 3 of my own, take me almost 2 hours from start to finish.
https://www.dieseltruckresource.com/...g-t271792.html
Old Jun 21, 2010 | 09:47 PM
schamran's Avatar
You can also use an iske tool to put the groove in the top of the cyllinder wall. Doesn't seem as common though.
Shorts
Sep 2, 2010 07:40 PM
BothellDiesel
Feb 3, 2007 07:26 AM
2 busy
Apr 19, 2005 06:59 PM
SuperDave4x4
Jun 21, 2004 06:10 PM
dcorneli
Jan 27, 2004 11:26 AM
