NV5600 + 4:10 = ?rpm?
Old 11-26-2008, 05:33 AM
ratsun's Avatar
For those that have a NV5600 and 4:10 axle ratio with the stock tires, can you post up the rpm your turning at 60mph?
I have this combo and sit at about 1975rpm and wondered if that is right or not?
This truck has a lift in it and I believe it may have had a taller tire on it and wondered if maybe the speedo was recalibrated for the larger tires?
Old 11-26-2008, 05:52 AM
98whitelightnin's Avatar
Mine is at 2100 at 70 mph.
Old 11-26-2008, 09:14 PM
ratsun's Avatar
I never got it up to 70 to see what it was there.
Anyone else?
Old 11-26-2008, 10:32 PM
alwaysonDTR
Alwaysworking's Avatar
http://www.grimmjeeper.com/gears.html
this will tell you what it is sapossed to be
Old 11-27-2008, 12:22 AM
ratsun's Avatar
Excellent!!! Just what I was lookin for
1950 @ 60mph is what the calculator says I should be at so it looks like the speedo is right on.
Old 11-27-2008, 12:54 AM
chansey's Avatar
Gears and Tires
I've done all the work for yo----go to http://www.sanco-bg.com/Conversion_NV5600.htm and you can see what combinations and speeds are available to you.
Good luck
Old 11-27-2008, 12:36 PM
jl4c's Avatar
http://www.jl4c.org/tdr/tires/tirecalc.zip
quicksilvr
06-16-2010 10:50 PM
53 willys
31
01-31-2008 02:24 PM
skeeter
01-18-2006 03:17 PM
dieselnewbie
04-13-2004 12:00 AM
fishin fever
02-22-2004 08:32 PM
Quick Reply: NV5600 + 4:10 = ?rpm?
