NV4500 swap questions..
Old 09-08-2008, 10:05 PM
Fullsizeyota's Avatar
I've got a 99 that i'm ditching the 47re for a 4500..
I'll have the tranny, clutch and bellhousing tomorrow.
how do the driveshaft lengths differ from manual to auto??
is the 47re rubber mount the same as a 4500 mount??
which wires on the tranny, or which wires do i need to swap or splice to bypass the park saftey switch so my truck will start once the 4500 is in?
thanks
Old 09-09-2008, 12:13 AM
DTR question asker
dieselfuelonly's Avatar
On my '96 the driveshafts were different lengths. I had the driveshaft that came off the donor truck too, so I'm not sure what the difference was since I just swapped them.
The rubber mount is different. On my 2WD the crossmember was the same - not sure about your 4WD though.
Hopefully this info I give you is correct since you have a 24v and I have a 12v, but I'm not positive... Good luck!
bri7070
06-23-2014 08:17 AM
SilverSootXpres
03-23-2010 07:18 PM
freds89
05-25-2009 01:52 AM
Fullsizeyota
05-11-2009 03:23 PM
OkJeeper
04-24-2003 10:32 AM
Quick Reply: NV4500 swap questions..
