Is this Normal.. ie: good bad or average
Old 11-10-2003, 06:10 AM
JBirney's Avatar
I just installed all of the mods in profile.. Stock tranny and exhaust for now.
I just came back to Delaware from indiana this weekend towing 10,000 lb trailer.
Coming across the mountain on I76 (last hill where ears pop) I had to turn the box up to 4 to maintain 68mph going up hill, s EGT's steady @ 1200.
TKS
Old 11-11-2003, 06:36 AM
Muted User
Valkyrie97's Avatar
Re:Is this Normal.. ie: good bad or average
I'd say you're doing OK but loosen up you're exhaust.
Old 11-11-2003, 07:01 AM
Mark Craig's Avatar
JBirney,
Valkyrie97 is right all you need to do now is free up the exhaust and the egts will drop some more so you can use all of that new power at all times. Call us if you need info.
Mark @ DPPI
Old 11-11-2003, 03:26 PM
Tiny's Avatar
Straight pipe it, EGTs will drop, and it sounds much better.
Old 11-12-2003, 07:14 AM
bulthisl's Avatar
Stacks!
Stacks!
Stacks! Stacks!
Stacks!
Stacks!
;D ;D ;D
Oh and by the way.
Did I mentions that Stacks would look good?
: Eddie : 8)
Old 11-12-2003, 01:40 PM
HOHN's Avatar
[quote author=JBirney link=board=4;threadid=22237;start=0#msg207914 date=1068466222]
TKS
[/quote]I think you are about normal considering the altitude and weight you are pulling. I wouldn't expect you to need that much box, though. You should be able to pull that grade w/just injectors, ESPECIALLY since you have the dodgezilla turbo.
What was your boost number? How high is the elevation? Only then can I really answer if something appears wrong to me.
Justin
westspeed
03-05-2011 07:46 AM
65fury
25
04-06-2007 08:16 AM
Buckshotram
01-09-2006 09:27 AM
C Pierce
03-21-2005 08:41 AM
Quick Reply: Is this Normal.. ie: good bad or average
