Is this Normal.. ie: good bad or average
Old Nov 10, 2003 | 06:10 AM
JBirney's Avatar
I just installed all of the mods in profile.. Stock tranny and exhaust for now.
I just came back to Delaware from indiana this weekend towing 10,000 lb trailer.
Coming across the mountain on I76 (last hill where ears pop) I had to turn the box up to 4 to maintain 68mph going up hill, s EGT's steady @ 1200.
TKS
Old Nov 11, 2003 | 06:36 AM
Valkyrie97's Avatar
Muted User
Re:Is this Normal.. ie: good bad or average
I'd say you're doing OK but loosen up you're exhaust.
Old Nov 11, 2003 | 07:01 AM
Mark Craig's Avatar
JBirney,
Valkyrie97 is right all you need to do now is free up the exhaust and the egts will drop some more so you can use all of that new power at all times. Call us if you need info.
Mark @ DPPI
Old Nov 11, 2003 | 03:26 PM
Tiny's Avatar
Straight pipe it, EGTs will drop, and it sounds much better.
Old Nov 12, 2003 | 07:14 AM
bulthisl's Avatar
Stacks!
Stacks!
Stacks! Stacks!
Stacks!
Stacks!
;D ;D ;D
Oh and by the way.
Did I mentions that Stacks would look good?
: Eddie : 8)
Old Nov 12, 2003 | 01:40 PM
HOHN's Avatar
[quote author=JBirney link=board=4;threadid=22237;start=0#msg207914 date=1068466222]
TKS
[/quote]I think you are about normal considering the altitude and weight you are pulling. I wouldn't expect you to need that much box, though. You should be able to pull that grade w/just injectors, ESPECIALLY since you have the dodgezilla turbo.
What was your boost number? How high is the elevation? Only then can I really answer if something appears wrong to me.
Justin
westspeed
Mar 5, 2011 07:46 AM
65fury
25
Apr 6, 2007 08:16 AM
Buckshotram
Jan 9, 2006 09:27 AM
C Pierce
Mar 21, 2005 08:41 AM
