non ic injectors in a intercooled engine
Old 08-01-2011, 06:44 AM
Brian.B's Avatar
can you put injectors from a 89 model truck into an 91.5,,,i was wandering cause i turned my fuel pin around 90 degrees and didnt feel a difference ,how much of a difference would it make if you could ,,,and one more thing would adding a 3200 rpm spring help me any...thanks
Old 08-01-2011, 07:22 AM
Onemoparnut's Avatar
No they won't fit.
Old 08-01-2011, 10:11 AM
Douglas2's Avatar
Originally Posted by Onemoparnut
No they won't fit.
They won't fit because the early injectors have a 9mm tip and the later ones have a 7mm tip. I think the later ones have a different spray angle too.
cheers,
Douglas
Old 08-01-2011, 11:23 AM
jimbo486's Avatar
Non i/c to i/c won't work because of what Douglas said. However, if you do buy aftermarket injectors, they come with 7mm nozzles. Therefore, you will need sleeves/adapters to make them work in your non i/c, 9mm head. Spray angles are a little different, non i/c spray at 155* and i/c spray at 145*. Some guys have found that running 145* with a non i/c pistons seems to burn fuel really well.
A 3200rpm spring will give it a better feel. Throttle response will be better as well. A great (and cheap!) mod for our pumps.
Old 08-01-2011, 03:55 PM
dieselJon's Avatar
I did for $125...
$100 for injectors
$25 for machine shop to turn them down to 7mm.
Spray angle is going to be outside the bowl but you can counteract that with a timing bump. Basically, you add POD injectors to it. I know, $ for $, I would do this again in a heartbeat.
Old 08-01-2011, 04:59 PM
366 Spring Chicken
Richie O's Avatar
Originally Posted by dieselJon
I did for $125...
$100 for injectors
Bumping timing will make it spray out worse. It makes it pop earlier, and that causes it to come out of the bowl.
Old 08-01-2011, 05:57 PM
jimbo486's Avatar
Maybe he meant in the other direction
Old 08-01-2011, 07:37 PM
dieselJon's Avatar
Yeah, I had it backwards.
Never mind the timing bump... I never got around to it but I was just doing what the guys with PODs had done.
1985cucv
06-12-2009 09:50 PM
bigblue70
05-29-2009 08:39 PM
440727
10-30-2008 07:14 PM
wannadiesel
03-31-2008 10:11 PM
sammy340
04-05-2005 03:55 PM
Quick Reply: non ic injectors in a intercooled engine
