no start just clicks
Old Oct 7, 2012 | 02:15 PM
marder's Avatar
New batteries, starter, fuses and relays. What's next? Oh its a 94 2 wd 5 speed. Tia.
Old Oct 7, 2012 | 03:30 PM
patdaly's Avatar
Clutch pedal switch?
Old Oct 7, 2012 | 04:16 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
poor ground???Even if the starter is new...Did you bench test it before installing??Now a days quality control is not the best..
Old Oct 7, 2012 | 06:43 PM
Mopar1973's Avatar
The newer cheapie starters are a common failure these days...its a shame. x2 on double checking the starter.
Old Oct 8, 2012 | 07:47 AM
patdaly's Avatar
Doh, just re-read and saw clicks.......... Starter contact or ground, ignore my clutch switch comment, there would be no click if it were bad.
Old Oct 8, 2012 | 12:30 PM
infidel's Avatar
99% sure that one of the new parts is the problem.
Most likely the starter.
Just because parts are new you can't assume they are good these days.
Old Oct 9, 2012 | 06:08 PM
Redlinear's Avatar
Battery cable or a bad connection cleverly disguised as a good connection.
Old Oct 12, 2012 | 01:50 PM
marder's Avatar
I haven't had a chance to tear into this again. Solenoid is working fine so I guess its not the fuseable link. Must be the starter. Its not doing anything, not even clicking. Ill take it off tomorrow and tear it apart.
Old Oct 14, 2012 | 05:30 PM
marder's Avatar
Ok, got the starter off and cant get it to spin just shoots the gear out but wont turn. I guess it's junk.
Will one off of a first gen work?
Old Oct 15, 2012 | 12:15 PM
infidel's Avatar
The 1st gen starters Larry B sells are different than the newer trucks.
Old Oct 15, 2012 | 12:26 PM
marder's Avatar
There is a guy that has one I can have Its a first gen starter Im wonderig if it will fit my 94? or can I take the motor off it and put it on this one?
Old Oct 15, 2012 | 07:32 PM
whiskers's Avatar
I've got my last couple starters from dbelectical on ebay. Decent prices and fast service and so far on 2 CTD's and my KUbota tractor they have been very reliable.
Old Oct 15, 2012 | 08:24 PM
Maybe you could rebuild your old 2nd gen starter...Maybe your contacts are just burnt out...You could get the larger contacts at Geno garage..
stidwell
Apr 5, 2008 06:24 AM
lezmark7
Oct 9, 2007 05:10 PM
dski63
Jul 28, 2007 12:29 AM
Sidewinder
Jan 26, 2004 09:43 PM
ts
Dec 10, 2002 11:35 PM
