no power help
Old 01-08-2008, 06:32 PM
jd green's Avatar
no power help
i ground my plate to a 100 and switched the washers around on the afc screwed the star wheel all the way forward and ground a little off the afc arm but the truck still has no power any ideas
Old 01-08-2008, 08:57 PM
twinturbos's Avatar
lots of smoke??
Old 01-08-2008, 09:10 PM
jd green's Avatar
it smokes very little on take off but no smoke
Old 01-08-2008, 09:40 PM
DRam11's Avatar
Check fuel and air. Clogged air filter? Leaking boost lines (including the intercooler)? Holed diaphram in either the AFC or wastegate actuator? Fuel filters? Fuel shutoff solenoid? Fuel return valve? If your outfit is over 100,000 miles and has a catalytic converter, check that. Heck, check the entire exhaust system for restrictions. Good luck.
Old 01-08-2008, 09:42 PM
twinturbos's Avatar
hmm.. have you adjusted your gov. arm correctly to your fuel plate?. i am running no plate and star wheel full forward. it smokes like a train.. what kind of washers in afc were you talkin about? like gov. spring washer mod?
Old 01-08-2008, 09:47 PM
twinturbos's Avatar
yeah, what DRam11 said. im still fighting the low power issue. but i would check everything that was listed in above post. thats a good start
Old 01-08-2008, 09:48 PM
jd green's Avatar
no if you take the washers on the diaframe and switch them my gov. is stock how do you adjust the gov. arm
Old 01-08-2008, 09:57 PM
twinturbos's Avatar
im sorry. i was not understanding the washer mod
Old 01-08-2008, 10:05 PM
jd green's Avatar
the front washer has a big lip on it if you move it to the back and the back to the front your rack will travel farther
thanasi
01-15-2007 09:53 AM
powerwagon440
01-20-2003 08:50 PM
pwabbott
12-20-2002 08:23 PM
Garz
11-17-2002 02:02 PM
Quick Reply: no power help
