No limited slip
Old 11-08-2005, 08:04 PM
Mr. Jimmy's Avatar
Thumbs down No limited slip
I decided to change the front and rear gear oil this afternoon and found that my new to me 95 has a single trac in the rear I can't believe a 4WD truck would come with a single trac. I guess I now have a 2WD instead of a 3WD. I will now take the LSD additive back to dealer for a refund
Old 11-08-2005, 08:21 PM
phox_mulder's Avatar
You and me both.
Talk about false advertising.
phox
Old 11-08-2005, 09:59 PM
cumminsdriver635's Avatar
I have a limited slip in my dana 70 that i will be able to sell probably, as my rear end went out(ring/pinion/bearings), but the carrier is all good with the limited slip. Not sure yet if i want to sell it or not, but if either of you are interested, shoot me a PM. Will only fit a dana 70 though i think. I am putting a limited slip dana 80 back in it hopefully. Single trac's suck big time. Thats why i refuse to buy a single trac to put back in my truck. The limited slip worked awesome!
Eric
Old 11-08-2005, 10:39 PM
TRCM's Avatar
believe it or not, most 4wd's are sold with a open front & rear diff.
Old 11-09-2005, 12:00 AM
displacedtexan's Avatar
According to a guy at the dealer all 4x4 are LSD... When asked how mine slipped through the cracks he was speechless
Old 11-09-2005, 08:54 AM
TxDiesel007's Avatar
I have a Dana 80 Rear
Im assuming a good limited slip cause if i stomp on it i lay down both tire marks really pretty. Ive never been in too precarious an offroad situation yet where i find out, oh wait yes i have.. when i got stuck, and both tires still spun. My build sheet also says limited slip rear differential so i go with it...
My ford tho, had open differentials on both axles, can you say UGH!! X 2???
Tx
Old 11-09-2005, 09:46 AM
infidel's Avatar
The guy at the dealer was BSing you.
By far most trucks are open diffs. LSD was an option.
Old 11-10-2005, 02:48 PM
T-Bone's Avatar
When I ordered my 1997 from the factory, LSD was not available with the 3:54 gears. A couple of years ago, I managed to find a used LSD carrier and swapped it in. Some of the best money I’ve spent on the truck.
T-Bone
Old 11-11-2005, 07:52 AM
Eskimo's Avatar
IIRC, the LSD was only available for a Dana 80 with the 4.10 gears. The D70, however, was avaialable with LSD for the 3.54's.
Are ya sure you've got an 80? what's your transfer case?
Old 11-11-2005, 08:20 AM
CTD NUT's Avatar
That is not entirely correct.......it was 01 and later D80's that only offered the LS with 4.10's. My 98.5 3500 has 3.54's w/ the LS and I have a buddy that has a 96 3500 with 3.54's and the factory equipped LS.
Old 11-11-2005, 11:30 AM
Dads 98 has 3:54's and Limited Slip.
Eric
Old 11-11-2005, 12:17 PM
Eric
as does my 96
Tx
Old 11-11-2005, 12:59 PM
Eskimo's Avatar
AAAhh, glad I caveated my post with IIRC...
I'd really like to find a gear-driven LSD for the 80 with 3.54's though...
Old 11-11-2005, 01:04 PM
CTD NUT's Avatar
IMO, there isn't a gear driven LS (like the Tru Trac) that will out perform the Powr-Lok.......IMO, the Powr-Lok is hands-down the best LS you can buy and since there is no gear driven LS offered by any manufacturer for the D80 that I'm aware of, it isn't really even a consideration.
Old 11-11-2005, 01:11 PM
Eskimo's Avatar
Just not a big fan of clutches on something that sees alot of miles, and is a street queen, but anything beats the 1-wheel wonder action!
So I'd wind up doing the D70 Powr-lok and drilling out the holes for the D80 ring gear bolts?
Quick Reply: No limited slip
