No heat ?
Old Jan 21, 2009 | 09:17 PM
farrms's Avatar
No heat ?
I have an 05 and it takes forever for it to heat up. You can let it idol for an hour and it still doesn't get warm. I was wondering if anyone had a good solution for this. I was thinking about just plain old cardboard or maybe some grill inserts. Thanks for any help fellas.
Old Jan 21, 2009 | 09:27 PM
DENVERDODGE04's Avatar
what kind of temps are you in?
Old Jan 21, 2009 | 09:28 PM
mrblond's Avatar
Could be thermostat stuck open but even still should have heated up at idle? How cold is it where u are?
Also, a stuck valve that directs hot water to the heater core. Could be bypassed to check, i don't know where the valve is on the CTD but usually its on the firewall, follow the heater hoses.
Old Jan 21, 2009 | 09:29 PM
https://www.dieseltruckresource.com/...t/23768/cat/11
This might help you.....
rich's Avatar
lot of northern guys run them cold weather front covers not sure what their called dont use them down here thank goodness. man 32 degrees is cold brrrr
Old Jan 21, 2009 | 09:30 PM
Spooler's Avatar
No valves on our trucks. They flow coolant to the heater core all the time. That is why folks put a valve on them so the A/C works better in the summer.
Old Jan 22, 2009 | 05:18 PM
farrms's Avatar
Well lately it has been single digits in the mornings and has been in the teens during the day, but still it should heat up more. I guess I will have to check into one of those covers. I was hoping somebody was having the same problem and had a fix for it.
Old Jan 22, 2009 | 07:06 PM
mrblond's Avatar
Thanks, I remember reading about it now.
I am about to do the vent tank mod and now I gotta look into the heater valve mod.
btw, back on topic, Im thinking thermostat stuck open now or he could be low on rad fluid?
Old Jan 23, 2009 | 05:30 PM
cowbizzoy's Avatar
mine takes eons to heat up at idle....its just not working hard enough to produce real heat i dont think. (then again, its -25 C here today...) If you want real heat look into an Espar Hydronic coolant heater, i think its a D5 you'd be after. I'm way to cheap though....
Old Jan 23, 2009 | 09:09 PM
rbox's Avatar
Mine won't give heat for 10 miles on a 30 degree morning. It's just their nature. Try plugging it in for a couple hours before starting. Worked wonders for me.
Old Jan 23, 2009 | 09:30 PM
CatDiesel_762's Avatar
Get yourself a cold front or a piece of cardboard to close off part of your airflow on cold days. This will heat up your truck better, but do not expect it to be a really warm unless you are driving down the road. Mine will only start to build up heat until I go down the road for about 10-20 minutes. Otherwise it will remain moderately cool.
Shawn
Old Jan 23, 2009 | 09:37 PM
Kowalski's Avatar
mine takes along time to warmup just idleing too. Last night it got down to -28C and she fired right up without being pluged in running synthetic oil helpes. It sounds like the thermo is stuck open but one thing I do to get mine to keep some heat is slide a piece of cardboard down right in front of the rad between the the oil coolers and rad and block the whole rad off. Works great at these temps and just watch temps when towing or the weather warms and if it starts to get hot just pull it out and toss it into tool box.
Old Jan 25, 2009 | 06:46 AM
farrms's Avatar
Thanks fellas. I kind of figured it might be in their nature. I was going to do the cardboard, or find some kind of grill inserts. It definitely is a good cold starting motor, just takes forever for heat.
tswcoaltrain
Nov 12, 2019 09:11 PM
bkrukow
Apr 29, 2011 06:42 PM
crossy
Dec 5, 2002 10:42 AM
crossy
Nov 1, 2002 05:16 AM
DieselDaze
Oct 25, 2002 06:50 PM
