New Engine Noise
Old May 26, 2004 | 05:44 AM
Pickle's Avatar
New Engine Noise
I have about 14,000 miles on my truck and I'm starting to hear a kind of knock that I have not heard before. If it were a gasser, I would check my valves/tappets. Is this normal for a Diesel? I didn't hear it the first 14,000 miles!
Old May 26, 2004 | 06:06 AM
bulabula's Avatar
Does it knock when its cold/warm/hot? Did you change fuel sources?
FWIW, mine knocks periodically for no apparent reason but then the knock goes away.
Old May 26, 2004 | 06:59 AM
Pickle's Avatar
It doesn't knock all the time. It seems to knock more warmed up.
I did buy fuel from a different place a few weeks ago, but I have refuled since.
Old May 26, 2004 | 07:56 PM
FiverBob's Avatar
Doug,
I am getting a little more noise from mine with some miles on it - - sounds like tappets in a gasser. Mechanic said all he has heard have done the same thing once they get about 10,000 on them. Now, if I could only get that drive train rattle out of it I would be happy.
Old May 27, 2004 | 05:01 AM
Pickle's Avatar
Thank you, FiverBob! I'll take that to the bank.
Old May 27, 2004 | 07:29 AM
rossn2's Avatar
Mine started making knocking, rattling noises, and had a vibration after 10k, cold or warm, but worse when cold.
I added 10-12 ounces of Rotella DFA to the last load of fuel and it all pretty much went away. I still have a slight tappet noise when first starting in morning....but goes away after about 1 minute. Not going to worry about it.
I'm gonna use the DFA on every fillup from now on...just a thought!
Smkn600CTD
May 22, 2012 07:21 PM
snowmanx
Jun 3, 2010 09:51 PM
ShowMe06
27
Jan 4, 2008 11:47 AM
chumstone
Mar 17, 2007 11:05 PM
swank
May 28, 2003 08:52 AM
