What needs to be done at 50k maintenance??
Old Jan 8, 2007 | 11:07 AM
VikingDiesel's Avatar
So far the stuff I will be doing soon:
*Oil Change
*Trans Flush with Trans filter
*Front and Read Diff service
*Fuel Filter
*Coolant flush
*grease suspension components
What else am I missing?
Old Jan 8, 2007 | 12:05 PM
John Faughn's Avatar
Flush the brake system also , power steering , transfer case , I would not let any fluid / lube stay in longer than 30,000 , except motor oil if it was syn with a dual by pass filtering system .
It may be early [ 80,000 ] adjust valves , you never know how it left the factory until you check it .
Old Jan 8, 2007 | 03:27 PM
SupaDupa's Avatar
Get a built tranny!!!!
Old Jan 8, 2007 | 11:04 PM
dodgepower88's Avatar
I would also suggest doing the valves.
It is probably not needed, but at least you won't have to worry about doing for a long while afterwards if you do it now.
Neight
13
Jan 16, 2009 09:34 PM
WideTrac
Mar 27, 2006 01:35 PM
O.fO.shO
Dec 19, 2005 10:41 PM
rednose
Jun 5, 2005 11:55 AM
ViperSBT
Nov 1, 2004 06:30 PM
