Question? 03, 5.9L HO tapping at 50K miles
Old Mar 24, 2006 | 03:01 PM
WideTrac's Avatar
Question Question? 03, 5.9L HO tapping at 50K miles
03 Dodge 5.9L HO Cummins with 50K miles. Engine has been quite until lately and now I notice a more pronounced rattle(Tapping) from the engine. Sounds like Gas engine with loose valve. The noise goes away as soon as I give any throttle. The dealer said there should be no problem and that it is normal when the engine reaches 50K miles or more to make more noise. The rack does not need checked until 130K miles per the manual.
It is no louder than some Diesel engines but has gotten louder as the engine breaks in so I am a little concerned.
Is this normal for the Dodge 5.9L HO engine?
Thanks for any help.
UPDATE > I was reading a posting from "Buffalo" and he stated "There are a number of us, out there, including myself, that have had injector knocking problems in the 3rd Gen. engines. It seems that if you are not running these newer engines hard, they can carbon-up the injector tips, causing the knocking. DC would not take care of my problem & that of many others. Some of us have cured the problem with the use of additives including injector cleaners. It worked for me."
I will try this and see if it solved the issue, Thanks Buffalo even if it wasn't on my thread....
Old Mar 24, 2006 | 04:03 PM
Blast Chamber's Avatar
Try adding some Seafoam to your diesel fuel. Some guys have even dumped the Seafoam directly into their fuel filter canister for additional injector cleaning.
http://www.seafoamsales.com/motorTuneUp.htm
Old Mar 25, 2006 | 04:57 AM
justcampin's Avatar
Seafoam and MMO worked for me the rattle went away
Old Mar 27, 2006 | 09:12 AM
WideTrac's Avatar
I tried some injector cleaner this weekend and it did seem to help the rattle but did not stop completely. I will pick up some Sea Foam today and give that a try.
Thanks for the help
Old Mar 27, 2006 | 09:28 AM
WideTrac, be aware that it may take a couple of tankfuls with Seafoam before the carbon gets completely cleaned out. During those tankfuls run it hard to get the cylinder temps high enough to burn off the crud. If you have a trailer it would help to pull it around to work the engine even harder.
Old Mar 27, 2006 | 11:34 AM
Kanab Ram's Avatar
Where can you buy SeaFoam at?
Old Mar 27, 2006 | 11:42 AM
I get it at the local farm supply store, but here is a link to other vendors.....
http://www.seafoamsales.com/buy.htm
Old Mar 27, 2006 | 01:35 PM
Buffalo's Avatar
I used the Sea Foam, also but, after clearing up my problem with fuel additives. Did this to insure clean injector tips.
I've, also, heard that the valves can be a bit out of adjustment. They may be within the spec.'s but, could be closer & possibly quieter.
Joe F.(Buffalo)
SCCSURF
16
Apr 28, 2010 09:25 AM
bluechrome
46
Feb 23, 2009 02:51 PM
Neight
13
Jan 16, 2009 09:34 PM
O.fO.shO
Dec 19, 2005 10:41 PM
ViperSBT
Nov 1, 2004 06:30 PM
