Need some advice...................
Old Oct 17, 2005 | 01:23 PM
hump's Avatar
My father-n-law is looking to purchase a 95 SLT dually 4x4 extended cab automatic tranny with 146,000 miles on it. He asked me to look over the truck and take it for a test drive, so I did. I now have a few questions to ask you more experienced diesel guys.
(1) I noticed a drip or two of oil coming out of the blow by tube once I returned from the test drive. Is this normal?
(2) The truck pulls to the right when driving down the highway. Could it need a front end alignment? Or a tire out of balance or low tire pressure?
I know for sure it needs 6 new tires and an exhaust system soon but otherwise the truck runs strong. Body is in real good shape for a 95. No rust and only 1 very small dent. Guy is asking $10,300 for the truck and the price seems reasonable to me. What do you guys think?
Thanks.........HUMP
Old Oct 17, 2005 | 02:08 PM
John Faughn's Avatar
The drip is difficult to go by ,? is how much in how many miles , the pull is nothing without new tires, then every 10,000-30,000 depending on your driving conditions, if the tires are bald then the alinement is a waste. the millage is good, the price may be a little high but would have to see . See if you can find out about mods. how much its been worked[ tow-hard driving, off road] weak points are trans[ mostly T.Q.] ft. end ,get off ground see if steering is tight[ side to side] ball joints [ top to bottom] and u- joints.
Old Oct 17, 2005 | 02:37 PM
hump's Avatar
John Faughn
I drove the truck for about 6 miles and when I came back and looked under it is when I noticed the small drip of oil coming out of the blow by tub. The drip was about the size of an eraser head on a pensil.
The tires are not bald as of yet, they should pass state inspection but I doubt they will give any decent traction in snow.
I know that the guy who currenty has it uses the truck to pull a goose neck cattle trailer, not sure how often or how much weight. He had the front ball joints and u joints replaced this month. The tranny, transfer case, brakes and steering all seemed very good. 4 Wheel drive worked like a charm. No additional concerns that I seen.
HUMP
Old Oct 17, 2005 | 04:04 PM
Wilson's Avatar
I would make sure the kdp has been tabbed. If you need more info on that, do a search and you will have plenty of reading. Good Luck!
Old Oct 18, 2005 | 08:28 PM
timeagain's Avatar
If he replaced the ball joints without a allinement, that would explane the pull!
dodgemaniac
Competition / Pulls / OffRoad
Jul 31, 2008 10:15 AM
bsj04
Sep 20, 2007 08:09 AM
ryan466
Aug 30, 2006 10:10 AM
Apr 20, 2003 11:16 PM
