I need more fuses!
Old Oct 17, 2007 | 11:27 PM
ez_lle71's Avatar
I need more fuses!
Ok, What my idea is to have a auxillary fuse panel under the hood mainly to hook up gauge lights, switched power, and other accessories. I don't like having all the wires i have going into the fuse block now! especially because it is not mounted permanent and it looks overloadable! Where should i get a fuse block and how should i go about hooking power to it? And any suggestions will be greatly welcomed. Also my whole point behind it is so i can add things later on and don't have to crawl under the dash and take the oem fuse panel down every time!
Thanks ez
Old Oct 18, 2007 | 12:42 AM
RuralCruiser007's Avatar
I know that you can get a fuse panel with 6 circuts that you can feed from the battery. I have seen this from Grote. I have also seen from Painless Wiring a lot of options. From Painless they have lots of options, they do retrofit wiring for muscle cars.
There are more out there but all I know of right now.
HTH
Old Oct 18, 2007 | 04:08 AM
KRB's Avatar
KRB
I like my Painless. I choose the weatherproof with half hot, half key on.
Old Oct 18, 2007 | 08:24 AM
ekk33's Avatar
I got mine out of a 95-98 chevy truck,
replaced all the fusible links, and gave me plenty of other places to plug extra stuff, in, can show pictures if you are interested.
Old Oct 18, 2007 | 09:16 AM
justagoodolboy's Avatar
Please do. I am interested as well.
(Hi-Jack over)
Old Oct 18, 2007 | 10:35 AM
rbrettctd's Avatar
I picked up a 6 circuit fuse block from Oreilleys for about $10. Mounted it behind my glovebox (well my brother did). Ran it to key on power and finished filling it yesterday. So now Im gonna add one to all-time power probably. Check my gallery for pictures of it. Real cheap and very effective and clean.
Old Oct 18, 2007 | 10:55 AM
ekk33's Avatar
I will run out at lunch and grab them
Old Oct 18, 2007 | 11:15 AM
ekk33's Avatar
Old Oct 18, 2007 | 11:22 AM
BearKiller's Avatar
BUSS makes a very nice six-terminal fuse-block that Advance has for (if I remember right) less than ten bucks.
Available in junk yards, later model trucks (and maybe cars--I never look at cars) have nice under-the-hood power-boxes, with relays, maxi-fuses, and regular fuses, complete with latchable weather-tight covers; Fords and Chevys for sure, not sure about Dodges.
I intend to completely relocate the fuse-blocks in our Dodges to a behind-the-seat location, much like the older/better big trucks use.
I had much rather flip a seat forward and stand erect, than lay flat of my back in a dirty floor-board with stuff falling in my eyes.
Old Oct 18, 2007 | 11:24 AM
ekk33's Avatar
I still need to clean up all the wires, just ran out of time to dress them all properly,
When i get home i will provide a list of how i broke down the circuits for the fuses.
This whole project took me a day to get where i was, lot of time spend soldering and shrink wrapping. but it could be done in a day now that i know how to break out the circuits.
My advice is to get two of the boxes if you can, this way you can have 2 60 amp fuses for the alternator feeds. the best way to look for the box is to check for the rounded dash on the chevy,not the square one, 95-98 I have about 30 dollars in the two boxes i have. Two boxes also allows me to get more of the pins for the mini-fuses, so theoretically i have enough pins to fill all the mini fuse spaces, when i need more of them.
I am also going to run my grid heaters off the external studs shown in the picture, so everything is in one box.
I moved the starter relay, and need to move the asd relay aslo, since there is plenty of space for relays also
I aslo found the square ford explorers have a lot of the big size fuses and a good selection of sizes, just need to do a little searching at the junkyard
Eric
Old Oct 18, 2007 | 11:35 AM
BearKiller's Avatar
My advice is to get two of the boxes.
Eric
YES, a very good point.
As they come equipped, there are many un-used fuse and relay pockets that are simply empty holes, with no guts in them.
Two, or more, power-blocks can be robbed of enough terminals to fill all the spaces.
Old Oct 18, 2007 | 09:41 PM
ez_lle71's Avatar
Thank you all for the great ideas! Now its time to hit the junkyards!
ez
Old Oct 18, 2007 | 09:52 PM
RumbleFish's Avatar
Not to mention messing with the major PITA of putting the stock fuse block back on the cover that is supposed to hold it up to the dash. I can honestly not remember the last time I saw one that fit together correctly. Worst design ever.
KAyers
Nov 6, 2006 04:50 PM
Moose_Jr
May 15, 2004 09:28 PM
Dave65
Jan 2, 2004 11:53 PM
bdog
Jul 29, 2003 09:51 PM
DarrellB
13
Jan 15, 2003 02:37 AM
