need help with oil pressure
Old Oct 4, 2006 | 04:22 PM
deaconn's Avatar
Question need help with oil pressure
I don't know much about deisels I have a 01 3/4 ton 104000 miles on it. Run fine it seems but when I come to a complete stops .Oil preesure gauge drops down to 0 and the check gauge light comes on . Any clues on whats wrong and how to fix.
Old Oct 4, 2006 | 04:33 PM
Diesel Dummy's Avatar
might be oil pressure sender or the oil pump, its not good if its that , i would not run it until you find out. There are plugs on the driverside of the engine to hook up an oil pressure gauge to check it manually.
Old Oct 4, 2006 | 08:55 PM
donhov's Avatar
My 04.5 went to 0 oil pressure when my oil got diluted from the fuel leaking thru the bad injector. Check your oil level and see if it is very high.
Good luck.
Old Oct 5, 2006 | 05:38 AM
DetroitDiesel71's Avatar
From: Dayton, NJ (temporarily while In USCG on Staten Island)
Install a mechanical at the L/O filter housing in the blank plug next to the turbo supply line. This will give an accurate measure of actual oil pressure. The plug on my 01 is 1/8", I ran a -4 aeroquip to a mechanical gauge in the cab, that way I know exactly what I am running.
Old Oct 5, 2006 | 09:10 AM
J BODY's Avatar
You need an oil psi switch. $287.00 at the dealer. Cheaper ones can be found online.
Old Oct 5, 2006 | 01:03 PM
pind's Avatar
oil pressure sending unit Cummins part # 4921511. $66 CDN right from cummins, retail for $87. Any cummins dealer can get them.
Also, Blue Streak PN PS407 is supposed to be the same thing, but I am not willing to order one to find out, so cummins it is.
5 minute install, pressure gauge is back to normal.
Old Oct 8, 2006 | 09:25 PM
deaconn's Avatar
thx alot I don,t know what I would do with out this site
tig
May 6, 2007 10:58 PM
Power Ram 250 C
Feb 20, 2007 11:08 AM
QWKRTNU
Oct 24, 2006 08:23 AM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
