need help fast
Old 01-15-2010, 03:55 PM
adam greene's Avatar
need help fast
dennt t stage 2 pin or m and h stage 3 and tell me why you think either one i need one fast i just broke my stock one
Old 01-15-2010, 04:11 PM
SmokemS's Avatar
get stock replacement and regrind it yourself save ya lots of money and they are more fun
Old 01-15-2010, 04:14 PM
they're both the same thing except the M3 will have a mellower grind towards the bottom so it doesn't smoke as much before the turbo comes in. but the grind at wide-open-throttle will be the same...
i'd say you'll be fine with stock injectors and a dennyT pin. you'll like the low end throttle response
they're both good guys that make them, id hate to choose one over the other since they do the same thing, just in a different way
Old 01-15-2010, 04:15 PM
Stock replacement costs more than a DennyT does...and you get more power out of an aftermarket one than a ground stocker can put out
Bosch shop quoted us $121.68 for that stupid thing a year ago , a stock one
Old 01-15-2010, 04:20 PM
will it be ok to crank it with the pin broke if i put it back togather
Old 01-15-2010, 04:48 PM
jimbo486's Avatar
i don't think you should chance it. as soon as you hit the throttle, you'll be in full fuel. the afc pin that rides up and down the ramp of the fuel cone will instantly move all the way back in the bore of the afc housing. when i replaced the o-ring on my afc pin, i was able to push it all the way through until it hit the back of the opening where the fuel cone resides. i just don't know if it could actually fall out of it's keeper or not. if it does, you'll have a heck of a fuel leak and it will be spewing out of the vent tube.
Old 01-15-2010, 05:09 PM
well i crunk it up for 10 sec. to move it out of the garage hopefully i didn mess it up i wish i would have seen this befor i did.
Old 01-15-2010, 05:11 PM
thats what i just PM'd him. thought so.
Old 01-15-2010, 05:12 PM
what should i do now
Old 01-15-2010, 05:14 PM
jimbo486's Avatar
pull the top off of the afc housing and look inside. if it's sticking out, reach in with a very narrow pair of needle-nosed plyers, grab it LIGHTLY and push it back in or towards the front of the engine. where'd the fuel pin break off? near the top of the ramp where it's kinda thin? and how did it break?
Old 01-15-2010, 05:17 PM
yea it broke off at the top. i dropped it on the floor i guess it just hit the right way idn
Old 01-15-2010, 05:40 PM
look down that hole where the fuel pin goes and if you see a little pin sticking out then lightly push that tiny pin back in, and insert your new dennyt
Old 01-15-2010, 05:47 PM
CONFEDERATESON's Avatar
ya i would go with the denny t just because i have one and love it!!! good luck with the pump it sounds like your in quite the pickle.
Old 01-15-2010, 11:23 PM
yea im just waitin on my denny t to get here how long does it usally take on shippin
Old 01-15-2010, 11:35 PM
1st Generation Admin
BC847's Avatar
I run the DennyT fuel pin.
It provides substantially more fuel in a WOT setting as compared to a ground stock/OEM pin.
But as Crossy's son has pointed out, the DennyT pin has a VERY aggressive ramp and as such, smokes very easily under part-throttle conditions with low boost.
I'd like to try something more along the lines of the M&H M3 pin. It's comparable to Denny's in the full fueling but has a much more gradual ramp getting there. As such, I believe it could run much cleaner around town.
These days I want a fuel pin that has a flat gradual ramp just like stock, but is capable of going just as deep as Denny's or AlwaysWorking's.
Quick Reply: need help fast
