need help with 98 to 02 engine swap 5.9L
Old 05-19-2006, 07:58 PM
scott h's Avatar
I am trying to install an 02 5.9L 24v HO into my 98 5.9L 24v dodge. I wanted to know what is required to install with the engine as far as computers and harnesses. I have the engine computer and the turbo and intake and exhaust manifolds. The 02 does not have a crank position sensor on it or even a ring on the crank to put the cps on it. The old engine required it. What do I do to get this to work. Everyone that I talked to says it won't work. Please help! The 02 engine reads the cam sensor for the timing? Do I need to get the computer for the firewall and the harness.
Old 05-20-2006, 06:27 AM
Truckman's Avatar
Cool Close But No Cigar
I just did the 1998.5 to 2001 Engine swap,But mine had a Crank sensor, I just put the 98.5 stuff on mine it was easy BUT your 2002 will be different. Do you have the Injector pump for the HO? I think you would need the Complete engine harness, all the sensors from the HO, ECM, BUT I dont know if you Gauges will work right,, Voltages are all different for that year. I dont know if it will work either,, You will be the test Subject we will learn by. Good Luck
Keep us posted..
Old 02-19-2016, 04:15 PM
Chris44's Avatar
Just wondering how you got around the crank sensor using the 98.5 pcm did u just relocate it and did you have to change the cam gear? I've got an 01 motor in my 2000 and running into some issues thanks
Bootiner
26
12-13-2017 09:49 PM
SWATPARAMEDIC
10-19-2009 03:25 PM
bigwheels94
07-11-2008 03:10 PM
Treangen
63
07-07-2008 07:42 PM
tdiot
07-02-2005 02:38 PM
Quick Reply: need help with 98 to 02 engine swap 5.9L
