Need EGT probe pictures please
Old 04-09-2007, 09:21 PM
boyeraz's Avatar
Please post your egt Pictures of 3 gen.
Also how due you keep the metal bits out of the line?
Old 04-09-2007, 09:27 PM
RamWheelsBy4's Avatar
Lots of threads on how to drill and tap the exhaust manifold for pyro sensor. Go slow, use grease on drill bit and tap, use magnet, leave engine running, drop turbo a little and put something to cover, etc. Just do a couple of searches until you find a process that you can do.
Here is picture of my first pyro sensor followed by picture of the second pyro sensor installed about an inch farther back on the manifold.
Old 04-09-2007, 09:32 PM
truckjunkie's Avatar
If you're looking for a pic of a post-turbo install, there's a couple in my gallery.
Old 04-09-2007, 09:35 PM
boyeraz's Avatar
Ram wheelsby4
Due also have a picture of the boots install
thanks
Old 04-09-2007, 09:38 PM
gerry's Avatar
how is this...
Some drop their turbo and tape it like I did, some use small drills and slowly step up so the chips are very small, some drill with grease and partially cover their tailpipe and drill while the truck is running to blow the stuff out...
All methods seem to work pretty well... I went the ultra safe route, dropped the turbo and taped it off.. I was also able to put my finger up in the port and feel the depth of the pyro..and make sure the holder was flush inside.
Gerry
Old 04-09-2007, 09:40 PM
Luvnacumns's Avatar
Here is both!!
SHane
Old 04-09-2007, 09:43 PM
CRXsi's Avatar
There are also some useful pics of the pyro install in my gallery as well.
Old 04-09-2007, 10:11 PM
Originally Posted by boyeraz
Ram wheelsby4
thanks
Used boost bolt, easiest install.
badme
04-05-2009 01:49 PM
tomd
12-12-2006 10:56 PM
wiredmojo
27
08-31-2005 11:44 AM
Dave65
10-08-2004 10:37 PM
Quick Reply: Need EGT probe pictures please
