EGT's all over, think I need a new probe.
Old 04-04-2009, 08:28 PM
badme's Avatar
My EGT's are all over the place. Climbing a hill they should be about 800 all the way up the hill. I am seeing anywhere from 130 to 800. The other day I left from a cold start and my edge j/a alarm went off for 1500. I only had gone 200 feet. Do I need a new probe? and where is a good place to get one?
Thanks
Eric
Old 04-05-2009, 12:38 AM
HelenaTDI's Avatar
I get most my parts from Genosgarage or Diesel Manor
http://www.genosgarage.com/departments.asp?dept=2
http://dieselmanor.com/
Old 04-05-2009, 12:47 AM
Crimedog's Avatar
First check all of your wiring connections. Is the needle sparatic or just slowly sweeping? I've had both, the sparratic movement was caused by a thermocouple wire cutting through the insulation and contacting the steel body. The sweeping was caused by something loose in the back of the gauge. I found that when I push on the gauge a certain way I can make the gauge go from its "false reading" to a realistic reading. I think an internal terminal or solder is a little loose on mine...
Old 04-05-2009, 08:34 AM
badme's Avatar
I am reading this with the edge juice, the readings will go from 130 to 900 when it acts up. I had a loose connection at the probe and tightening it made it better but it still is not right.
Old 04-05-2009, 01:49 PM
Crimedog's Avatar
My bad, I was under the impression you had an analog gauge. Sounds like it very well could be the thermocouple then.
tomd
12-12-2006 10:56 PM
wiredmojo
27
08-31-2005 11:44 AM
Dave65
14
10-08-2004 10:37 PM
bigfoot
08-14-2004 02:22 PM
Quick Reply: EGT's all over, think I need a new probe.
