To much timing?
Old 08-09-2011, 09:52 PM
sleeperman's Avatar
To much timing?
Well today I put a better injection pump on my truck and when I did I jumped a tooth on the pump gear got it running and at low rpm the coolant temp it hotter than normal. Isn't this from to much timing?
Old 08-09-2011, 10:15 PM
1st Generation Admin
BC847's Avatar
Not necessarily from too much timing, but yes, advancing the injection event timing will allow more heat of combustion to be absorbed by the head, piston, and cylinder, as compared to the original timing (in addition to being converted to more energy to the crank as work).
That being said, since more heat is being used in the engine, and not being dumped out the exhaust, you may also notice a little less boost as the turbo is powered by the otherwise wasted energy of heat in the exhaust gases.
Old 08-10-2011, 11:53 PM
Rampage1967's Avatar
My truck didn't want to climb hills when i over advanced the timing.
Old 08-13-2011, 04:47 PM
sleeperman's Avatar
After I wrote this I went and retarded the timing as much as I could with leaving the gear jumped and now it idles fine but when reved up it smokes white and misses. Any ideas ?
AlCorr
28
11-27-2008 10:05 AM
goose2w1
08-15-2007 10:09 PM
06dmc
09-07-2006 09:47 AM
ssigmon
05-26-2006 03:54 PM
redhornet
05-28-2004 06:06 PM
Quick Reply: To much timing?
