Moog upper and lower ball joints
Old Feb 23, 2009 | 02:29 PM
D-Roc's Avatar
I'm probably going with these on my 06 soon, but am having difficulty trying to find the part numbers. I've searched on the site, but get a number of part #'s which makes it confusing. Looking for the heavy duty option (if it exists). The guy at Napa gave me a couple of part numbers:
Upper: 260-1580
Lower: 260-1579
but I don't know if they are correct, or if there are other better options. I emailed Federal/Mogul, but they didn't reply back.
Lots of BJ threads lately, I know. Thanks in advance.
Old Feb 23, 2009 | 02:33 PM
D-Roc's Avatar
Or if there is a better option that I can get access to (I'm in Canada, New Brunswick) that would be better.
Thanks again.
Old Feb 23, 2009 | 04:11 PM
GreyTD's Avatar
Rockauto.com has ACDELCO, Spicer and Moog. The moogs are adjustable. The others are straight replacements. all greaseable.
Old Feb 23, 2009 | 04:51 PM
D-Roc's Avatar
With the adjustable ones, is this an advantage over anything, can they be installed at a default? Just wondering what I would get out of that. My truck is stock suspension.
Old Feb 23, 2009 | 05:02 PM
Country23047's Avatar
How many miles before I should expect ball joints to be bad?
Old Feb 23, 2009 | 05:42 PM
GreyTD's Avatar
The adjustable are good if you are having alignment issues. I don't see any other advantage. I went with spicers.
Country23047 --You can check your ball joints any time you want. Jackup one side, using a long pry bar, put under wheel and lift, watch for movement up/down on lower joint. Nice tight joints don't move, oem have slight movement, but still should be less than 1/8" IMO. Upper joint while tire still in air grab tire at 12 and 6 and rock in and out, should not have move.
Old Feb 23, 2009 | 10:30 PM
04 ranch truck's Avatar
I changed mine out at about 80,000 miles and installed the Napa ones. I dont have a part number but as far as what they look like compared to the Spicer brand they are a way better product.
Old Feb 24, 2009 | 12:15 PM
SOhappy's Avatar
My two sets of OEMs have started to wander noticeably after 35,000 miles. Time for aftermarket.
Old Feb 27, 2009 | 08:26 PM
Niv's Avatar
Niv
I have had good luck with moog and have agood warranty and always get greasable. upper ball joint $ 70 lower $82
Old Mar 1, 2009 | 12:20 AM
Highway 4x4's Avatar
Give Dynatrac a call, they are starting to build a greesable and rebuildable ball joint.
EdmontonCanada
37
Feb 4, 2016 12:02 PM
exwrestler
Apr 28, 2014 09:55 AM
rjm022
Oct 23, 2008 10:49 PM
abc4yew
Oct 19, 2007 02:37 PM
ollie32
Jul 30, 2007 06:20 PM
